Stretch from 4:3 to 16:9 for online Streams
Daniells
Post Sun Mar 17, 2013 6:23 pm
Anyone can help me on Profile for my LG TV LG60pm670s to stretch online 4:3 streams to 16:9 hier an example of online stream i wish to see in 16:9:
rtmp://live1.gsp.ro/live playpath=a2 swfUrl=http://ivm.inin.ro/swf/player_live4.swf pageUrl=http://ro-tv.ucoz.ro/index/antena_2/0-374 live=1 swfVfy=1
Post Sun Mar 17, 2013 7:47 pm
Re: Stretch from 4:3 to 16:9 for online Streams
first try with a Bravia profile, if it works, we can try to update the LG profile
Daniells
Post Sun Mar 17, 2013 8:17 pm
Hi Zip,
Thanks for reply. I tested all Sony Bravia profiles with no change on picture on my TV. Any other option?
Post Sun Mar 17, 2013 8:48 pm
it looks like the source is 4:3, right? Does it look stretched on your TV or does it have the right 4:3 acpect?
Daniells
Post Sun Mar 17, 2013 8:54 pm
the source seems to be 4:3 and show in my tv 4:3 but resolution showing in info from serviiio is 720x576 I just want to stretch it to 16:9 because i have black stripes left an right and not looking good on big 60 inches tv
Post Sun Mar 17, 2013 11:32 pm
720x576 is 4:3. Is there not a zoom setting on the TV?
Daniells
Post Mon Mar 18, 2013 11:24 am
Is allready zoomed, without zoom is showing smaller but also 4:3
Post Mon Mar 18, 2013 11:38 am
Daniells wrote:the source seems to be 4:3 and show in my tv 4:3 but resolution showing in info from serviiio is 720x576 I just want to stretch it to 16:9 because i have black stripes left an right and not looking good on big 60 inches tv
This is how a 4:3 source had to be displayed on a 16:9 TV, otherwise, you have to use a TV's option to stretch to 16:9 display (but image will not be realistic).
On modern TVs, you have many zoom options.
Daniells
Post Mon Mar 18, 2013 11:57 am
I put the stream link on my Dreambox and is showing full 16:9(the dreambox scaled) with no lost on quality. When using Serviio i have only two options on my TV ,fullscreen or original picture, and in fullscreen is only 4:3 as I mentioned with stripes left and right. You r right I have many zoom options in my TV but when using serviio I cannot use Zoom just fullscreen or original picture.
Daniells
Post Thu Mar 21, 2013 5:36 pm
Nobody has an Idea?
Ryo
Post Sun Mar 31, 2013 12:59 pm
SAME PROBLEM HERE! But Offline Streams ;)
Local network.. Windows 7 to TV
LG 32 LW5500.
All my recordings are MPEG2, 720x576 PAL ... is showing as 4:3 but they are 16: 9 !!!
Zooming options in TV are ORIGINAL (very small and 4:§) and Fullscren (Bars left and Right light it wheres 4:3 ... )
So the Streaming Service is USELESS :-(
Return to LG
