LG Media Station MS408D
ajwatt
Post Sun Aug 11, 2013 4:39 am
I am having trouble steaming files, both large and small, from my server to my LG Media Station MS408D
Sometimes it all works perfectly but more often than not it doesn't. If I go into the DLNA option on the menu and select Serviio, the file titles/names appear - but sometimes the file length (run time) does not appear. If the file starts to play it shutters and stops then won't play.
I was streaming wirelessly but have wired the modem straight to the media station via a ethernet cable - the issue continues.
I am using a Wireless N150 ADSL2+ Modem Router (DSL-2730B)
My friend has the same media station and manages to stream wirelessly without the playback starting and stopping
Do you have any ideas or suggestions?
Regards
AJ
Post Mon Aug 12, 2013 7:21 pm
Re: LG Media Station MS408D
Are you and your friend using the same profile?
Might be router too.
Return to LG
