Serviio to transcode hi10 video with subtitle???
skyhot004
Post Sat Dec 07, 2013 10:53 am
I tried
Changing to directv HD PVR
And that is not working
It transcode video great
But no subtitle
I have tried this setting from Sendaran
           <!-- Remux WTV files to MPEG-PS with no transcoding-->
              <Matches container="wtv" />
           <!-- transcode unsupported video codecs into mpeg-ts, h264 and ac3 audio -->
           <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
              <Matches container="asf" />
              <Matches container="flv" />
              <Matches container="ogg" />
              <Matches container="matroska" vCodec="h264" profile="high_10" levelGreaterThan ="4.1" />
           <!-- transcode unsupported audio codecs in MKV into AC3 -->
           <Video targetContainer="mpegts" targetACodec="ac3" >
              <Matches container="matroska" aCodec="flac" />
              <Matches container="matroska" aCodec="vorbis" />
              <Matches container="matroska" aCodec="truehd" />
           <!-- unsupported audio will be transcoded into lpcm audio -->
              <Matches container="flac" />
              <Matches container="adts" />
           </Audio>
   <HardSubsTranscoding>
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" />
   </HardSubsTranscoding>
   <Subtitles>
      <SoftSubs mime-type="text/srt;text/x-ssa;text/x-ass;text/microdvd" />
      <HardSubs>
         <RequiredFor container="matroska" />
      </HardSubs>
   </Subtitles>
Nope not working
Video won't play
I'm currently mixing setting but no luck
Directv with subtitle transcode from Sendaran
Nah not working
This is video i'm trying to watch
Unique ID                                : 183054665153475304653438204613807342802 (0x89B70BCDB9F5128091AE035D440084D2)
Complete name                            : C:\Users\sirasith\Downloads\[Commie] Persona 4 Complete\[Commie] Persona 4 - 01v2 [D13B7533].mkv
File size                                : 258 MiB
Duration                                 : 24mn 29s
Overall bit rate                         : 1 475 Kbps
Encoded date                             : UTC 2012-02-06 22:47:28
Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 11:55:43
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes
Format profile                           : High 10@L5.0
Format settings, ReFrames                : 16 frames
Muxing mode                              : Header stripping
Duration                                 : 24mn 29s
Bit depth                                : 10 bits
Writing library                          : x264 core 118 r2085+614 d1cc25d
Encoding settings                        : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.80 / psy_rd=0.60:0.05 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.80 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
Codec ID                                 : A_AAC
Duration                                 : 24mn 29s
Channel count                            : 2 channels
Title                                    : Commie
Language                                 : Japanese
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Menu
00:00:00.033                             : en:Intro
00:01:52.029                             : en:OP
00:03:21.451                             : en:Part A
00:14:43.816                             : en:Part B
00:22:44.654                             : en:ED
00:24:14.631                             : en:Preview
BTW I use bundled ffmpeg from serviio
I have this problem for week
I register to ask you as last resort
Post Tue Dec 17, 2013 1:28 pm
Re: Serviio to transcode hi10 video with subtitle???
Enable Embedded subtitles in the console. If it still doesn't work, enable Burned-in subtitles too.
peterpan
Post Sun Dec 22, 2013 5:41 pm
i have the new serviio running but it keep stopping and the subtitle do what they like on off when they like ;)
Come And See The New Social Network At :- http://www.linkbook.t15.org
This Is A New Website So Come And Be A Part Of It Please
Return to LG
