[SOLVED] Error after modify profiles.xml
xpto09
Post Fri Sep 30, 2011 2:45 am
I am using XML copy editor.
I added the lines:
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4" name="">avi</MediaFormatProfile>
Now I have:
(the message from xml copy editor is: profiles.xml is valid)
<Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
      </MediaFormatProfiles>
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" aCodec="ac3" />
However, this modification only works when I make it "on the fly".
After a reboot, when I try to start serviio.sh:
2011-09-29 23:29:17,448 INFO  [MediaServer] ------------------------------------------------------------------------
2011-09-29 23:29:17,459 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-09-29 23:29:17,459 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-09-29 23:29:17,459 INFO  [MediaServer] http://www.serviio.org
2011-09-29 23:29:17,460 INFO  [MediaServer]
2011-09-29 23:29:17,460 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-09-29 23:29:17,460 INFO  [MediaServer] OS Linux i386 2.6.38-11-generic
2011-09-29 23:29:17,460 INFO  [MediaServer] File encoding: UTF-8
2011-09-29 23:29:17,461 INFO  [MediaServer] Headless mode enabled: true
2011-09-29 23:29:17,461 INFO  [MediaServer] User home dir: /home/mrcs
2011-09-29 23:29:17,461 INFO  [MediaServer] Temp dir: /tmp
2011-09-29 23:29:17,461 INFO  [MediaServer] ------------------------------------------------------------------------
2011-09-29 23:29:17,900 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-09-29 23:29:17,967 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-29 23:29:19,960 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2011-09-29 23:29:33,027 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: Content is not allowed in prolog.
2011-09-29 23:29:33,029 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
   at org.serviio.MediaServer.main(MediaServer.java:105)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:693)
   at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:128)
   at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:154)
   ... 1 more
2011-09-29 23:30:16,859 INFO  [ServiioConsole] Starting Serviio Console
2011-09-29 23:30:19,511 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-29 23:30:24,699 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-09-29 23:30:28,824 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Conexão recusada
2011-09-29 23:30:28,958 INFO  [Messages] Loaded console message bundle for locale: en
2011-09-29 23:30:32,999 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Conexão recusada
2011-09-29 23:30:44,099 INFO  [ServiioConsole] Leaving Serviio Console
Error:
What do I have to do to solve this?
Post Fri Sep 30, 2011 5:16 am
Re: Error after modify profiles.xml
edit it in notepad instead, obviously your xml copy editor is adding something to the file serviio doesnt like..
Post Fri Sep 30, 2011 10:16 am
yep, there is probably some (hidden) character/byte at the beginning of the file, possibly also wrong encoding
xpto09
Post Sat Oct 01, 2011 1:45 pm
The problem is not the editor.
I put the line:
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
here:
   <Profile id="1" name="Generic DLNA profile">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ProtocolInfo>DLNA</ProtocolInfo>
      <DeviceDescription>
         <FriendlyName>Serviio ({computerName})</FriendlyName>
         <ModelName>Serviio Media Server</ModelName>
         <Manufacturer>Petr Nejedly</Manufacturer>
      </DeviceDescription>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1" name="LPCM">LPCM16_44_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AMR</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
Post Sat Oct 01, 2011 1:55 pm
Re: Error after modify profiles.xml (solved)
erm that line is wrong anyways and from the portion of the profile.xml file you posted show as corrupted.
should be this
<MediaFormatProfile mime-type="video/mp4">AVI</MediaFormatProfile>
attach your profile.xml file here and will try and sort it out for you so its correct.
xpto09
Post Sun Oct 02, 2011 12:58 pm
There is only way to work.
This line
must be inside
      <DeviceDescription>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2" name="LPCM">LPCM16_44_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1" name="LPCM">LPCM16_48_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2" name="LPCM">LPCM16_48_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/flac">FLAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/ogg">OGG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-flv">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-dvr">DVR_MS</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/wtv">WTV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/ogg">OGV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">VC1_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
      <OnlineTranscoding>
            <Matches container="mp4"/>
            <Matches container="flv"/>
         <Audio targetContainer="mp3">
         </Audio>
      </OnlineTranscoding>
      <AutomaticImageRotation>false</AutomaticImageRotation>
      <LimitImageResolution>true</LimitImageResolution>
      ========================= DO NOT EDIT - end   ====================================
I put it in
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
there is error.
I tried put the line
but there is error.
Post Sun Oct 02, 2011 5:03 pm
DO NOT edit the generic profile or you will break all the other profile.
now i will look at this once im at work and give you a working profile to test for your pannasoic.
EDIT: here is corrected profiles.xml file please copy this to your serviio installation folder.
profiles.xml
(55.21 KiB) Downloaded 1475 times
FYI: the correct information you needed to add is below but as you messed up your profile.xml file using an XML editor, please use the copy above
xpto09
Post Sun Oct 02, 2011 8:05 pm
Not worked.
2011-10-02 16:51:55,725 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-02 16:51:55,739 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-10-02 16:51:55,739 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-10-02 16:51:55,739 INFO  [MediaServer] http://www.serviio.org
2011-10-02 16:51:55,739 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-10-02 16:51:55,739 INFO  [MediaServer] OS Linux i386 2.6.38-11-generic
2011-10-02 16:51:55,739 INFO  [MediaServer] File encoding: US-ASCII
2011-10-02 16:51:55,740 INFO  [MediaServer] Headless mode enabled: true
2011-10-02 16:51:55,740 INFO  [MediaServer] User home dir: /root
2011-10-02 16:51:55,740 INFO  [MediaServer] Temp dir: /tmp
2011-10-02 16:51:55,740 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-02 16:51:55,927 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-10-02 16:51:55,988 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-10-02 16:51:58,217 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-elt.1: Cannot find the declaration of element 'MediaFormatProfile'.
2011-10-02 16:51:58,218 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
The problem is this:
If I return the profile that is modified, there is no error:
2011-10-02 16:57:19,296 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-02 16:57:19,318 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-10-02 16:57:19,318 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-10-02 16:57:19,318 INFO  [MediaServer] http://www.serviio.org
2011-10-02 16:57:19,318 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-10-02 16:57:19,318 INFO  [MediaServer] OS Linux i386 2.6.38-11-generic
2011-10-02 16:57:19,318 INFO  [MediaServer] File encoding: US-ASCII
2011-10-02 16:57:19,319 INFO  [MediaServer] Headless mode enabled: true
2011-10-02 16:57:19,319 INFO  [MediaServer] User home dir: /root
2011-10-02 16:57:19,319 INFO  [MediaServer] Temp dir: /tmp
2011-10-02 16:57:19,319 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-02 16:57:19,495 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-10-02 16:57:19,569 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-10-02 16:57:22,049 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-10-02 16:57:22,584 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-10-02 16:57:22,808 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-10-02 16:57:22,919 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-10-02 16:57:23,034 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-10-02 16:57:23,125 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-10-02 16:57:23,211 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-10-02 16:57:23,407 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-10-02 16:57:23,441 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-10-02 16:57:23,712 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-10-02 16:57:24,122 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-10-02 16:57:24,285 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-10-02 16:57:24,463 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-10-02 16:57:24,507 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-10-02 16:57:24,531 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-10-02 16:57:24,606 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-10-02 16:57:24,642 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-10-02 16:57:24,725 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-10-02 16:57:25,063 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-10-02 16:57:25,332 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-10-02 16:57:25,406 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-10-02 16:57:25,440 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-10-02 16:57:25,443 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-10-02 16:57:25,443 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-10-02 16:57:25,445 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-02 16:57:25,445 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-10-02 16:57:25,445 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1317585445445, LastAccessTime = 1317585445445, getTimeToLiveSeconds() = -1, createTime = 1317585445445 ]
2011-10-02 16:57:25,469 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-10-02 16:57:25,469 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-02 16:57:25,469 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-10-02 16:57:25,469 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-02 16:57:25,469 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-10-02 16:57:25,469 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-10-02 16:57:25,469 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-02 16:57:25,469 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-10-02 16:57:25,470 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-10-02 16:57:25,470 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-02 16:57:25,470 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-10-02 16:57:25,470 INFO  [CompositeCacheConfigurator] Finished configuration in 28 ms.
2011-10-02 16:57:25,156 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-10-02 16:57:25,156 INFO  [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-10-02 16:57:25,431 INFO  [PluginCompilerThread] Looking for plugins at /home/mrcs/pms/serviio-0.6.0.1/plugins
2011-10-02 16:57:25,431 INFO  [PluginCompilerThread] Started looking for plugins
2011-10-02 16:57:27,351 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-10-02 16:57:27,695 INFO  [WebServer] WebServer starting on port 8895
2011-10-02 16:57:27,782 INFO  [EventDispatcher] Starting EventDispatcher
2011-10-02 16:57:27,783 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-10-02 16:57:27,784 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-10-02 16:57:27,820 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.10, timeout = 0
2011-10-02 16:57:27,824 INFO  [RendererSearchSender] Searching for Renderer devices
2011-10-02 16:57:27,824 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-10-02 16:57:29,511 INFO  [PluginCompilerThread] Added plugin SnotrUrlExtractor (Snotr.groovy)
2011-10-02 16:57:29,805 INFO  [PluginCompilerThread] Added plugin YouTubeUrlExctractor (Youtube.groovy)
2011-10-02 16:57:30,213 INFO  [PluginCompilerThread] Added plugin SC2CastUrlExctractor (SC2Casts.groovy)
2011-10-02 16:57:53,996 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-10-02 16:57:54,009 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-02 16:57:54,030 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Post Sun Oct 02, 2011 8:08 pm
ok maybe i typed it wrong, let me check.
Edit yep i typed it wrong lol mybad see below working version.
profiles.xml
(55.14 KiB) Downloaded 1679 times
xpto09
Post Sun Oct 02, 2011 9:15 pm
Worked!
Post Sun Oct 02, 2011 9:33 pm
xpto09 wrote:Worked!
Of course it did and now the other profiles arent broken either and yur LG works :P
Return to LG
