New update
• Page 1 of 1
The new update doesnt allow my 55 LG Smart TV to find the DLNA Server. I have stopped and restarted the server but on the TV menu, DLNA is still greyed out. Does anyone know how to fix this? The last version was awesome. I was able to install the software and the TV found the Server and I was watching TV from the PC without any problems.
Re: New update
check your network and port settings.
Re: New update
If things worked the first time without me touching network settings or port settings, how would I know what I'm looking for?
I reinstalled the previous version and as you probably guessed, it doesn't work either.
So, where do I go and what do I do?
Do I reboot the modem like I had too so that my iPhone could use the wireless?
Will the reboot reset the network ?
The router is a Cisco N router.
Thanks for any help in advance.
Re: New update
driver120 wrote:If things worked the first time without me touching network settings or port settings, how would I know what I'm looking for?
restarting router is the first step deffinately, and checking all connections, then check IP has not changed and you have entereed the IP of pc running serviio into bound ip field in console, and then lastly check TCP port 8895 and UDP 1900 are open in your firewall.
Re: New update
try re-running the network setup on the tv, it works for me
• Page 1 of 1
