Q about supported file types
abbu
Post Thu May 19, 2011 7:47 pm
Re: Q about supported file types
ok I've corrected and also added some stuff to config from other threat. viewtopic.php?f=13&t=555&hilit=panasonic+profile&start=30
had to delete some avi stuff as these were ok but after adding content they were not recognized. I will attach config for convenience.
Now mpg ,mpeg ,wmv are playing ok
all avi run fine, got one type where the sound is not recognized.
vob also run ok, just need the subtitles to work. ad the srt files ?
profiles.xml
config
(37.04 KiB) Downloaded 1117 times
Post Thu May 19, 2011 8:47 pm
Can you run ffmpeg -i on the file that the audio does not work on. See signature for details.
abbu
Post Fri May 20, 2011 7:23 am
AVI file (d.avi) :sound is not played on vt20
H:\W7\Serviio\lib>ffmpeg.exe -i l:\test\d.avi
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 15.00 (15/1)
Input #0, avi, from 'l:\test\d.avi':
Duration: 00:10:00.06, start: 0.000000, bitrate: 1027 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 320x240 [PAR 1:1 DAR 4:3], 15 fps, 15 tb
r, 15 tbn, 30k tbc
Stream #0.1: Audio: pcm_s16le, 22050 Hz, 1 channels, s16, 352 kb/s
H:\W7\Serviio\lib>
Post Fri May 20, 2011 10:21 am
abbu wrote:AVI file (d.avi) :sound is not played on vt20
Stream #0.0: Video: mpeg4, yuv420p, 320x240 [PAR 1:1 DAR 4:3], 15 fps, 15 tbr, 15 tbn, 30k tbc
Not sure that pcm audio is supported with AVI container and mpeg4 videocodec, I think audio must be transcode to aac or ac3
           <Video targetContainer="mpegts" targetACodec="aac">
            <Matches container="avi" vCodec="mpeg4" aCodec="lpcm" />
or
abbu
Post Fri May 20, 2011 1:14 pm
in both cases my vt 20 doen not recognize the avi file anymore :"can not read file "
Post Fri May 20, 2011 2:18 pm
So:
abbu
Post Fri May 20, 2011 7:20 pm
Now it works, accept that after 4 min the screen freezes and sound continious
Post Fri May 20, 2011 8:10 pm
How is your network setup?
abbu
Post Sat May 21, 2011 7:53 am
moltra wrote:How is your network setup?
pc-router-switch-Home av plug-panasonic
abbu
Post Wed May 25, 2011 5:08 pm
The freezing does not seem te be a real issue. So far many thanks for helping me out. This media server realy has turned out to be a great pleasure.
The only remaining file type which does not play is "flv". Any suggestions on how to make this file type play?
Post Wed May 25, 2011 5:13 pm
abbu wrote:The only remaining file type which does not play is "flv". Any suggestions on how to make this file type play?
<Matches container="flv" />
Previous
Return to Panasonic
