tc p42x3 don't show .srt file
christian_hw
Post Sun Jan 01, 2012 1:13 pm
dear all, I have a VIERA tc p42x3, and I can't do the serviio server show me the subtitles for my movies, this have the same name of the mkv file. i am using the lastest version of serviio. and using the default panasonic profile. i hope you can help me please.
Best regards, and sorry for my english i am from chile
Post Sun Jan 01, 2012 1:37 pm
Re: tc p42x3 don't show .srt file
Post Sun Jan 01, 2012 6:14 pm
yep, looks like Viera doesnt support srt for mkv files.
christian_hw
Post Wed Jan 11, 2012 12:39 pm
does anyone knows wich sibtitle format viera tv suport?
Post Wed Jan 11, 2012 12:55 pm
probably a few but Serviio only supports srt
voodooo
Post Wed Jan 11, 2012 1:17 pm
Have you tried to remux the mkv file adding the srt ? It works for me. (use mkvtoolnix v3.4.0).
christian_hw
Post Wed Jan 11, 2012 1:53 pm
i will try it
how many time takt that? for example with a file of 2Gb?
voodooo
Post Wed Jan 11, 2012 3:00 pm
For 11 gbs 1080p mkv file about 4 mins on I7 2.0.
christian_hw
Post Thu Jan 12, 2012 1:33 am
hi,I tried, but unsuccess, do you know if the srt file must encoding in a specific format like utf8 or another.?
voodooo
Post Thu Jan 12, 2012 12:08 pm
christian_hw wrote:hi,I tried, but unsuccess, do you know if the srt file must encoding in a specific format like utf8 or another.?
Humm don't know for shure but all my srt are UTF8: S_TEXT/UTF8.
Regards.
christian_hw
Post Thu Jan 12, 2012 2:39 pm
Hi, my viera model doesn't support subtitle with mkv file, do you have any idea how can get play subtitle?
voodooo
Post Thu Jan 12, 2012 5:09 pm
Can you follow these steps and post the results in the forum ? http://wiki.serviio.org/doku.php?id=device_sf
christian_hw
Post Fri Jan 13, 2012 2:37 am
hi, I connected the tv to my router, and it took ip correctly, but i can't see it as device on Device spy.
any suggestions?
voodooo
Post Fri Jan 13, 2012 1:00 pm
christian_hw wrote:hi, I connected the tv to my router, and it took ip correctly, but i can't see it as device on Device spy.
any suggestions?
Assuming you can play mkv files with Serviio there should be no network/DLNA problem..
Just to make shure, after you remux the mkv file with srt (UTF8) and play it, when you go to "options -> subtitles" (ON TV) it says that there are no subtitles or after remux the file don't play at all ?
Return to Panasonic
