Panasonic L42E30H
cwlaualex
Post Tue Jan 17, 2012 3:15 pm
Panasonic L42E30H
After going through some of the posts regarding playing back mkv with external subtitle. I got the following suggestion.
1. Rename the mkv file to avi extension as someone said Panasonic TV doesn't read subtitle for mkv but avi only.
2. Remux the mkv with the subtitle
I have tried different scenario but all failed.
First, the following is my device info.
2012-01-17 22:19:58,846 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 24d64742-f3b2-3c8c-8ebc-5fe79f342cbb from 192.168.16.103 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.16.100:8895,X-PANASONIC-Registration: VklFUkEgRTMwIFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2012-01-17 22:19:58,847 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.16.103
2012-01-17 22:19:58,849 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.16.100:8895,X-PANASONIC-Registration: VklFUkEgRTMwIFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
I've tried different methods but it all seems not working. If transcoding is enabled, the movie can be played back without subtitle. However, if transcoding is disabled, the movie cannot be read at all.
Please advise what to do. Thanks!
Without transcoding and remuxed.txt
Transcoding disabled and srt has been embed
(2.37 KiB) Downloaded 806 times
Without transcoding.txt
(3.24 KiB) Downloaded 721 times
With transcoding.txt
Transcoding enabled
(2.63 KiB) Downloaded 713 times
voodooo
Post Tue Jan 17, 2012 3:51 pm
Re: Panasonic L42E30H
Hi.
Not shure how you remuxed it, but for my TV it only works with v.3.4.0 of mkvtoolnix.
Good luck.
Post Tue Jan 17, 2012 3:54 pm
Could you also provide information about your mkv file with MediaInfo tool result and "ffmpeg -i" result (see signature)?
cwlaualex
Post Wed Jan 18, 2012 8:36 am
Certainly.
ffmpeg.txt
ffmpeg -i result
(1.35 KiB) Downloaded 789 times
Captain.America.The.First.Avenger.RERip.1080p.BluRay.x264-MaxHD.mkv.txt
MedioInfo result
(6.06 KiB) Downloaded 681 times
Post Wed Jan 18, 2012 10:14 am
Thanks,
Muxing mode : Header stripping
Header Compression, not supported by your panasonic.
Remux your mkv with proper option on mkvtoolnix : http://wiki.serviio.org/doku.php?id=header_com
cwlaualex
Post Wed Jan 18, 2012 6:17 pm
Thanks a lot! It works. The aspect ratio become correct as well! :D
cwlaualex
Post Thu Jan 19, 2012 7:24 am
Actually, how can I check whether my TV support mkv header compression? Moreover, are all mkv with header compression will show muxing mode as header stripping? How do I determine a mkv is compressed in header?
Post Thu Jan 19, 2012 9:27 am
header stripping = header compression
Return to Panasonic
