Missing sources, Unicode incorrect, How to export/import?
gordon
Post Wed Nov 14, 2012 10:32 pm
As shown in attachment
I Checked stream URL, Added and Saved 49 Live Streams in Online sources Library.
The problems are,
1. Only first 20 of them are shown in my Panasonic P50ST50 (I finished adding yesterday night, it is still the same this morning)
2. Unicode characters are shown correctly in Display name, but incorrectly in Online sources Source Name list.
3. Also, may I ask, how can I export/import Live Streams and other settings so that I can uninstall Serviio and then re-install?
gordon
Post Fri Nov 16, 2012 12:00 am
Re: Missing sources, Unicode incorrect, How to export/import
Had a look at serviio.log, possilby the following error is related to problem 1: missing sources.
2012-11-15 21:59:25,090 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:135)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:242)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:182)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItems(ContainerNode.java:83)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:152)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
Caused by: java.lang.NullPointerException
at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoMPEG2TSFormat(MediaFormatProfileResolver.java:258)
at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoFormat(MediaFormatProfileResolver.java:100)
at org.serviio.dlna.MediaFormatProfileResolver.resolve(MediaFormatProfileResolver.java:48)
at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:79)
at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:45)
at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForProfile(AbstractDeliveryEngine.java:70)
at org.serviio.delivery.MediaResourceRetrievalStrategy.getMediaInfoForAvailableProfiles(MediaResourceRetrievalStrategy.java:74)
at org.serviio.upnp.service.contentdirectory.command.ResourceValuesBuilder.buildResources(ResourceValuesBuilder.java:58)
at org.serviio.upnp.service.contentdirectory.command.AbstractListOnlineObjectsByHierarchyCommand.retrieveList(AbstractListOnlineObjectsByHierarchyCommand.java:126)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:129)
... 17 more
miksa
Post Fri Nov 16, 2012 1:37 am
gordon wrote:3. Also, may I ask, how can I export/import Live Streams and other settings so that I can uninstall Serviio and then re-install?
for export/import Serviio repository you may want to look at REST API.
- Mike
gordon
Post Fri Nov 16, 2012 3:08 am
Thank you so much, miksa. You saved me lots of work.
http://<pc5dczc_server_ip>:23424/rest/repository
Return to Panasonic
