DMP-BDT220 unable to play video files
thenamelessthing
Post Tue Dec 04, 2012 5:46 am
Hi! I have read many thing in the wiki/forum about transcoding profile,etc. But i'm not able to play any video files.
Here is a the info:
Sample video file I have try:
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (2500000/104271)
Input #0, avi, from 'testmovie.avi':
encoder : VirtualDubMod 1.5.10.2 Fr | www.trad-fr.com || (build 2540/release)
Duration: 01:52:44.81, start: 0.000000, bitrate: 866 kb/s
Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 720x304 [PAR 1:1 DAR 45:19], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
I also add a BDT220 profile in the profile.xml at the end of the file just before </profiles> (I got this in another topic on the forum)
<Profile id="BDT220" name="Panasonic - BDT220" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>DMP-BDT220/221</FriendlyName>
<Manufacturer>Panasonic</Manufacturer>
</UPnPSearch>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="15360">
<Matches container="*"/>
<Audio targetContainer="mp3">
<Matches container="*" />
</Audio>
</Profiles>
And for finish here is the error in the log:
012-12-03 23:39:07,418 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-202-BDT220-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-202-BDT220-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
Anybody can help me?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Tue Dec 04, 2012 9:21 am
Re: DMP-BDT220 unable to play video files
Find the ffmpeg command line used to transcode your file.
Then try the same in a local terminal an check the ffmpeg error.
What is your OS, if is Linux, update your ffmpeg and take care of configuration opion : http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
thenamelessthing
Post Tue Dec 04, 2012 11:42 am
I use Ubuntu 12.04 server.
Do you have any idea where the command used is located?
I will try your suggestion tonight. Thanks you.
To be continued...
Return to Panasonic
Users browsing this forum: No registered users and 54 guests
