Having to restart serviio service on each use
Niggy
Post Sun Dec 02, 2012 9:59 pm
Hi, have tried to find in forum and wikki but can't seem to find this.
I have just purchased a Panasonic TXL32E5B and installed servo. It all indexed fine and shows up and can connect and plays and is superb !!
My only question is ; If I watch a file via serviio and swap back to TV then go back to servo it doesn't show up in the media server list. If I stop and restart the service it appears and works again. I know it doesn't surmount a massive issue but if I am not at home and any other family use it they haven't got access the Mac the service runs on to stop and start the service.
I can't seem to find a setting anywhere about the service, is there a work around on this ?
Great app was going to purchase apple TV but think this is going to stall my purchase. Once this is sorted next stop is looking into the plugin to stream urls !
Thanks in advance & apologies if a repeat post.
Specs
Serviio 1.0.1 in evaluation ( At moment - soon to purchase if it all works )
Everything on default setting as it works
iMac with OSX V 10.8.2 ( Mountain Lion )
Hard wired ethernet
Panasonic TXL32E5B with all updates done
Niggy
Post Wed Dec 05, 2012 7:56 pm
Re: Having to restart serviio service on each use
Any takers on this for any ideas ?
Please
Post Wed Dec 05, 2012 8:46 pm
Can you post your serviio.log file and ip addresses of your tv and computer. Also what is the make and model of your router.
Niggy
Post Mon Dec 10, 2012 12:58 pm
Seems if I leave it on the "No media server" found page for about 45 seconds it finds it again and works fine. :)
Thanks for post
ddc
Post Thu Dec 27, 2012 11:06 pm
I am having the same problem. I've been looking around and I read one post that said default "refresh" rate for DLNA server is 900 seconds (15 min)? So when I turn the DLNA function on my TV after about this amount of time, it recognizes my computer. Otherwise, I have to restart my computer for it to show up. Am I off base? What can be done about this?
Return to Panasonic
