After upgrade to 1.1 - Can't pause or fast-forward
peje1873
Post Wed Dec 26, 2012 6:51 pm
As above,
I upgraded and now I can no longer pause or fast-forward anything I play. Anyone know how to correct this? Alternatively if you could direct me to the old install files I can downgrade.
Thanks in advance,
Pete.
Panasonic TX-P42GT30B
Panasonic DMR-HW120EBK
Panasonic DMP-BDT110EB
Custom Home Server: Intel DH77KC with i7-2600K, 8GB DDR3, 2TB System Drive, 7.5TB RAID5 array with hotspare.
S/W: W7 Ultimate, Serviio, SABnzbd, SickBeard, Couch Potato, Headphones & FileZilla Server.
Post Mon Dec 31, 2012 6:05 pm
Re: After upgrade to 1.1 - Can't pause or fast-forward
Are you using the same profile as before?
peje1873
Post Mon Dec 31, 2012 6:09 pm
I was using the same profile. I uninstalled and reinstalled the old version and its works perfectly.
Pete
Post Mon Dec 31, 2012 6:12 pm
Can you try to enable detailed log, play the affected file, try to ffwd, and post the log here. Do this with both versions so that I can compare if there are any differences. Thanks.
peje1873
Post Mon Dec 31, 2012 6:15 pm
I'll try it at the weekend if I get a chance.
Pete
Return to Panasonic
