Panasonic DMP-BD110
kirkm
Post Sat Jun 23, 2012 6:04 am
Panasonic DMP-BD110
Does anyone else have this model BluRay player and working DLNA?
Mine shows the menu, and has played m2ts files with Twonky (which I've just removed in favour of Serviio).
It will not play any other format though. Just says 'Can't connect' even though it is.
My second player, DMP-BD77 does play fine.
Post Sat Aug 18, 2012 3:59 pm
Re: Panasonic DMP-BD110
I have this player, and it will work fine with my networked files (although I have issues with some particular formats). What I don't have working is trying to use online resources. I have installed plugins for PBS Kids, Crackle, MyiPlayer, Veetle and a number of Hulu categories. On my Panasonic ST50 Plasma I can stream these fine, so I know the plug-ins are working, but on the BD110 I am unable to see anything. I get the file cannot be played error. I can't even scroll the list of sites on the player. If I try to see more than the first page, I get an error that I can't connect to the server, which is silly.
Anyway, long explanation for the fact that yes, I have a BD110 player and its DLNA function works fine. I also have two Windows 7 computers in the house that I can stream from as well with no issues.
Post Sun Aug 19, 2012 11:20 am
When you get the disconnect error durng browsing, are there any errors in the log? if not, can you enable detailed log and recreate the disconnection, the post the log. And did you make any changes on the Presentation tab in Serviio console?
Post Sun Aug 19, 2012 8:56 pm
Hi Zip. If that question was to me, here's what was in the log for that time period last night:
2012-08-18 22:20:56,312 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-1000000000060007-10-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-1000000000060007-10-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-08-18 22:20:56,328 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-1000000000060007-10-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
If I need to enable more detailed logs, let me know. However, I leave town tomorrow morning and will be gone for 5 days. I'll be checking the forum while I'm gone, but won't be able to access my server until I return.
Post Sat Aug 25, 2012 7:48 pm
Zip:
Attached is a snippit of my log with debug enabled. I only copied the section that pertained to my attempt to scroll the list of locations from my Serviio server to my BluRay player. Well, I tried to attach but I can't find the button for it on the forum, so I'll just paste it here. 10.0.0.27 is the IP address of my BD Player. edit: I found the wayt to attach just as I hit submit. It figures... :oops:
2012-08-24 19:50:15,395 DEBUG [WebServer] Incoming connection from /10.0.0.27:4681
2012-08-24 19:50:15,395 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:15,395 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2012-08-24 19:50:15,395 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=3fbbebfb-ed28-4c7f-96fe-1b22d66bcbfa) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://10.0.0.27:60605/event_0
2012-08-24 19:50:15,473 DEBUG [EventDispatcher] Sending event notification #0 for subscription 3fbbebfb-ed28-4c7f-96fe-1b22d66bcbfa to endpoint http://10.0.0.27:60605/event_0
2012-08-24 19:50:15,489 DEBUG [RequestExecutor] Sending HTTP request to 10.0.0.27:60605
2012-08-24 19:50:15,504 DEBUG [EventDispatcher] Event notification sent and received successfully
2012-08-24 19:50:15,520 DEBUG [WebServer] Incoming connection from /10.0.0.27:4682
2012-08-24 19:50:15,520 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:15,520 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.27:
2012-08-24 19:50:15,520 DEBUG [ContentDirectory] Browse() called for renderer Blu-ray Disc Player (profile viera2010) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @childCount,dc:date,dc:creator,upnp:channelNr,upnp:channelName,upnp:genre,upnp:album,res,res@duration,res@size,res@bitrate,res@dlna:ifoFileURI,res@protocolInfo, startIndex = 0, count = 5, sortCriteria =
2012-08-24 19:50:15,520 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-24 19:50:15,520 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=5) [No_Restriction]
2012-08-24 19:50:15,535 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-08-24 19:50:15,551 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-08-24 19:50:15,551 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-24 19:50:15,551 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:15,551 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-24 19:50:15,551 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2012-08-24 19:50:15,551 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:15,567 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-24 19:50:22,535 DEBUG [WebServer] Incoming connection from /10.0.0.27:4683
2012-08-24 19:50:22,535 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:22,535 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.27:
2012-08-24 19:50:22,535 DEBUG [ContentDirectory] Browse() called for renderer Blu-ray Disc Player (profile viera2010) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @childCount,dc:date,dc:creator,upnp:channelNr,upnp:channelName,upnp:genre,upnp:album,res,res@duration,res@size,res@bitrate,res@dlna:ifoFileURI,res@protocolInfo, startIndex = 5, count = 5, sortCriteria =
2012-08-24 19:50:22,535 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-24 19:50:22,535 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=5, count=5) [No_Restriction]
2012-08-24 19:50:22,551 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,551 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,567 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,567 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-08-24 19:50:22,567 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-08-24 19:50:22,567 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-24 19:50:22,567 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,567 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-24 19:50:22,645 DEBUG [WebServer] Incoming connection from /10.0.0.27:4684
2012-08-24 19:50:22,645 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:22,645 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.27:
2012-08-24 19:50:22,645 DEBUG [ContentDirectory] Browse() called for renderer Blu-ray Disc Player (profile viera2010) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @childCount,dc:date,dc:creator,upnp:channelNr,upnp:channelName,upnp:genre,upnp:album,res,res@duration,res@size,res@bitrate,res@dlna:ifoFileURI,res@protocolInfo, startIndex = 8, count = 2, sortCriteria =
2012-08-24 19:50:22,645 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-24 19:50:22,645 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=8, count=2) [No_Restriction]
2012-08-24 19:50:22,660 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,660 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,660 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,676 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,676 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-24 19:50:22,676 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-24 19:50:26,551 DEBUG [WebServer] Incoming connection from /10.0.0.27:4685
2012-08-24 19:50:26,551 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:26,551 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ContentDirectory and subscription uuid:3fbbebfb-ed28-4c7f-96fe-1b22d66bcbfa
2012-08-24 19:50:26,551 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=3fbbebfb-ed28-4c7f-96fe-1b22d66bcbfa) removed for service urn:upnp-org:serviceId:ContentDirectory
2012-08-24 19:50:26,629 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.0.0.27:1025
2012-08-24 19:50:26,629 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:26,629 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.0.0.27:1025
2012-08-24 19:50:27,379 DEBUG [WebServer] Incoming connection from /10.0.0.27:4687
2012-08-24 19:50:27,379 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:27,379 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device a673ebd8-46e1-3a38-aa35-7c394cdbca24 from 10.0.0.27 (headers = [HOST: 10.0.0.2:8895,ACCEPT-LANGUAGE: ja,CONNECTION: close])
2012-08-24 19:50:27,379 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 10.0.0.2:8895,ACCEPT-LANGUAGE: ja,CONNECTION: close]
2012-08-24 19:50:27,379 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera (2010)'
2012-08-24 19:50:27,848 DEBUG [WebServer] Incoming connection from /10.0.0.27:4689
2012-08-24 19:50:27,848 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:29,348 DEBUG [WebServer] Incoming connection from /10.0.0.27:4693
2012-08-24 19:50:29,348 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:30,332 DEBUG [WebServer] Incoming connection from /10.0.0.27:4697
2012-08-24 19:50:30,348 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.27
2012-08-24 19:50:35,723 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-24 19:50:35,723 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-24 19:50:35,723 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-24 19:50:35,739 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2012-08-24 19:50:35,754 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 6)
2012-08-24 19:50:35,754 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-08-24 19:50:35,770 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 8)
2012-08-24 19:50:35,770 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-08-24 19:50:35,770 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-08-24 19:50:35,785 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
kirkm
Post Mon Aug 27, 2012 8:36 am
Thanks for the replies atc98092 and Petr. Still no luck here, but will muddle on. BD 110 may just be a bit rubbishy.
Post Tue Sep 11, 2012 12:15 pm
atc98092 wrote:Zip:
Thanks. And what is your Presentation setting? Default or did you change it in the console?
Post Tue Sep 11, 2012 11:54 pm
zip wrote:
atc98092 wrote:Zip:
I can't remember if I've used default. I have it set on Panasonic Viera (2010), since there's no specific Panasonic BluRay Player presentation. It seems to work well with just about everything I have ripped to my network. The only issue I have is playing a ripped BluRay movie giving me an audio track I don't want. Usually it seems to be Spanish or French, but some movies (such as Star Wars) give me the descriptive voice service. I have no idea if my ripping software (WinX Blu-Ray Decrypter) is jumbling the default audio track. My Sony SNP N200 allows selecting different audio tracks, and I can get the english HD track that way. Doesn't do me any good in the bedroom though, because that's where the BD110 is. :(
Post Thu Oct 18, 2012 12:30 pm
Re: Panasonic DMP-BDT110
Zip,
I have settled on the Viera (2010) profile for this BD player. It's the only one that seems to work correctly with MKV files. I still have an issue though. If I pause the movie, it won't continue again after hitting play. Same if I try to fast forward. It just freezes. I have to stop and start, which of course returns me to the beginning of the video.
Also, I still can't play any online resource. I get a "Cannot play file" immediately after hitting play. What's the best way to troubleshoot this? I know the online resource is configured correctly, as they will play on my Viera ST30 TV and Sony SNP-N200 streaming box.
Thanks!
thenamelessthing
Post Mon Jan 14, 2013 2:52 am
Hi I have the same fast forward problem! Any idea?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Return to Panasonic
