New Panasonic Profiles Requiring Testers.
Post Fri Dec 14, 2012 11:02 pm
Re: New Panasonic Profiles Requiring Testers.
Apparently you have to first convert the text srt file to sub (image based) using this: http://www.videohelp.com/tools/AVIAddXSubs
Then you can add the sub file into a subtitles track via FFmpeg and it should play. Unfortunately FFmpeg can't do that for now, so it won't work with Serviio.
erhamm
Post Wed Jan 16, 2013 1:51 am
The final profile for my Viera GT without Avi support works great and the aspect ratio is perfect (no more stretched heads) but the TV doesn't support DTS so the sound has disappeared for all the MKV's I am playing. Ideas?
Post Thu Jan 17, 2013 4:53 pm
did you try one of the built-in Viera profiles?
erhamm
Post Mon Jan 21, 2013 7:27 pm
I've tried the built in Viera profiles and some of the custom ones found in this thread. With a MKV I either get no sound and the aspect of the picture is perfect or I get sound and the picture is stretched vertically. I think i need a profile where for MKV with DTS is transcodes the audio but not the video.
Post Tue Jan 22, 2013 2:27 pm
It should already transcode only audio. The problem with aspect ratio is that mpegts doesn't store the value (mkv does) and it expects it in the h264 stream (it's probably missing in your file).
https://lists.ffmpeg.org/pipermail/ffmp ... 06543.html
So we would have to transcode video as well to keep the aspect ratio correct.
erhamm
Post Wed Jan 23, 2013 4:11 am
Thanks, I'm still a newbie with everything. Is there a change to the profile I should do or do I need to transcode the video ahead of time?
Post Thu Jan 24, 2013 3:14 pm
either ahead of time or you could set up transcoding of the video as well (instead of just remuxing it)
Previous
Return to Panasonic
