Panasonic DT50 streaming stops suddenly and film restarts
rivella
Post Mon Feb 04, 2013 2:44 pm
some of my videos suddenly stop after some minutes and restart immediatly. It is reproducable. Here are the ffmpeg-info and the debug information from the time the video restarts:
ffmpeg
Unique ID                                : 178374457367869870971776656007790921820 (0x8631ABBE8538853A563291410A19085C)
Complete name                            : D:\Moviez\Homeland\Homeland.S01E03.Die.Halskette.GERMAN.DUBBED.DL.1080p.BluRay.x264-TVP\tvp-homeland-s01e03-1080p.mkv
File size                                : 4.03 GiB
Duration                                 : 47mn 0s
Overall bit rate                         : 12.3 Mbps
Movie name                               : Homeland.S01E03.Die.Halskette.GERMAN.DUBBED.DL.1080p.BluRay.x264-TVP
Encoded date                             : UTC 2013-02-03 23:17:53
Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 13 2011 06:24:21
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Duration                                 : 47mn 0s
Bit rate                                 : 10.1 Mbps
Maximum bit rate                         : 40.0 Mbps
Height                                   : 1 080 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.195
Stream size                              : 3.40 GiB (84%)
Title                                    : tvp-homeland-s01e03-1080p
Writing library                          : x264 core 125 r2208 d9d2288
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=10089 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.0
Language                                 : German
Forced                                   : Yes
Audio #1
Duration                                 : 47mn 0s
Bit rate                                 : 192 Kbps
Stream size                              : 64.6 MiB (2%)
Language                                 : German
Forced                                   : Yes
Audio #2
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 47mn 0s
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 507 MiB (12%)
debug
2013-02-04 15:21:01,596 DEBUG [WebServer] Incoming connection from /169.254.57.152:62139
2013-02-04 15:21:01,596 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.57.152
2013-02-04 15:21:01,597 DEBUG [ResourceTransportRequestHandler] GET /resource/196/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=4643-,Connection: close,Host: 169.254.248.99:8895]]
2013-02-04 15:21:01,597 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.57.152
2013-02-04 15:21:01,597 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/169.254.57.152, Profile=Panasonic Viera G/GT/DT/UT/VT (2011/2012)'
2013-02-04 15:21:01,598 DEBUG [ResourceDeliveryProcessor] Request for resource 196 and type 'MEDIA_ITEM' received
2013-02-04 15:21:01,598 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 196 (local)
2013-02-04 15:21:01,598 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 196)
2013-02-04 15:21:01,598 DEBUG [VideoDAOImpl] Reading a Video (id = 196)
2013-02-04 15:21:01,599 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 196, format MATROSKA and profile Panasonic Viera G/GT/DT/UT/VT (2011/2012)
2013-02-04 15:21:01,599 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 196 (local)
2013-02-04 15:21:01,599 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 196)
2013-02-04 15:21:01,600 DEBUG [VideoDAOImpl] Reading a Video (id = 196)
2013-02-04 15:21:01,601 DEBUG [VideoDeliveryEngine] Delivering item '196' for client 'IPAddress=/169.254.57.152, Profile=Panasonic Viera G/GT/DT/UT/VT (2011/2012)'
2013-02-04 15:21:01,601 DEBUG [VideoDeliveryEngine] Delivering file 'tvp-homeland-s01e03-1080p.mkv' in native format
2013-02-04 15:21:01,601 DEBUG [MediaItemDAOImpl] Getting file of media item 196
2013-02-04 15:21:01,602 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 196) as read
2013-02-04 15:21:01,603 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-02-04 15:21:01,603 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 503344484
2013-02-04 15:21:01,603 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-02-04 15:21:01,603 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 503344484,Date: Mon, 04 Feb 2013 14:21:01 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 4643-503349126/503349127,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-02-04 15:21:12,546 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /169.254.57.152:50050
2013-02-04 15:21:12,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.57.152
2013-02-04 15:21:12,546 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.57.152:50050
2013-02-04 15:21:12,547 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.57.152:50050
2013-02-04 15:21:12,550 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /169.254.57.152:50051
2013-02-04 15:21:12,550 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.57.152
2013-02-04 15:21:12,551 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /169.254.57.152:50051
2013-02-04 15:21:12,551 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 169.254.57.152
Hope you can help.
My system:
Win7 x64
serviio 1.1
Panasonic DT50
Connected via Ethernet
regards
rivella
Post Sun Feb 17, 2013 4:11 pm
Re: Panasonic DT50 streaming stops suddenly and film restart
Does ffmpeg fail? (see the log)
Return to Panasonic
