TC-L47E5 TV and Transcoding MKV with DTS Audio
Wulvor
Post Wed Jan 23, 2013 12:10 am
Hello All, I am a complete n00b at all of this, but it seems on any mkv that is using DTS audio gets transcoded and stretched the video vertically.
Using the controls on the TV I cannot adjust the aspect ratio, it doesn't change anything.
The video I am trying to play is 1280x544 . I decided find another video online to test and it does the same thing.
Again , I am a complete novice at this, any help would be appreciated. Thanks
Edit: Forgot to post, I am using the Panasonic Viera E/S/ST/VT (2011) Profile, but have tried the other one and the same thing occurs
Edit #2, I found an avi file that also stretches vertically. It is an xvid file with A52 sound.
Wulvor
Post Wed Jan 23, 2013 6:12 pm
Re: TC-L47E5 TV and Transcoding MKV with DTS Audio
Here is the ffmpeg -i output of one of the culprit files.
g-config
Input #0, matroska,webm, from 'C:\Users\Ken\Desktop\Once Upon a Time in the West
.mkv':
Duration: 02:46:01.95, start: 0.000000, bitrate: 5656 kb/s
Chapter #0.0: start 0.000000, end 624.415000
title : 00:00:00.000
Chapter #0.1: start 624.415000, end 912.078000
title : 00:10:24.415
Chapter #0.2: start 912.078000, end 1240.030000
title : 00:15:12.078
Chapter #0.3: start 1240.030000, end 1479.311000
title : 00:20:40.030
Chapter #0.4: start 1479.311000, end 1993.033000
title : 00:24:39.311
Chapter #0.5: start 1993.033000, end 2560.850000
title : 00:33:13.033
Chapter #0.6: start 2560.850000, end 2808.347000
title : 00:42:40.850
Chapter #0.7: start 2808.347000, end 3252.332000
title : 00:46:48.347
Chapter #0.8: start 3252.332000, end 3411.408000
title : 00:54:12.332
Chapter #0.9: start 3411.408000, end 3540.871000
title : 00:56:51.408
Chapter #0.10: start 3540.871000, end 4013.051000
title : 00:59:00.871
Chapter #0.11: start 4013.051000, end 4340.461000
title : 01:06:53.051
Chapter #0.12: start 4340.461000, end 4802.798000
title : 01:12:20.461
Chapter #0.13: start 4802.798000, end 4985.314000
title : 01:20:02.798
Chapter #0.14: start 4985.314000, end 5373.618000
title : 01:23:05.314
Chapter #0.15: start 5373.618000, end 5721.257000
title : 01:29:33.618
Chapter #0.16: start 5721.257000, end 5928.047000
title : 01:35:21.257
Chapter #0.17: start 5928.047000, end 6193.813000
title : 01:38:48.047
Chapter #0.18: start 6193.813000, end 6487.606000
title : 01:43:13.813
Chapter #0.19: start 6487.606000, end 6637.881000
title : 01:48:07.606
Chapter #0.20: start 6637.881000, end 6901.186000
title : 01:50:37.881
Chapter #0.21: start 6901.186000, end 7134.335000
title : 01:55:01.186
Chapter #0.22: start 7134.335000, end 7481.224000
title : 01:58:54.335
Chapter #0.23: start 7481.224000, end 7841.667000
title : 02:04:41.224
Chapter #0.24: start 7841.667000, end 8136.253000
title : 02:10:41.667
Chapter #0.25: start 8136.253000, end 8587.662000
title : 02:15:36.253
Chapter #0.26: start 8587.662000, end 8763.588000
title : 02:23:07.662
Chapter #0.27: start 8763.588000, end 8973.965000
title : 02:26:03.588
Chapter #0.28: start 8973.965000, end 9120.445000
title : 02:29:33.965
Chapter #0.29: start 9120.445000, end 9449.690000
title : 02:32:00.445
Chapter #0.30: start 9449.690000, end 9691.056000
title : 02:37:29.690
Chapter #0.31: start 9691.056000, end 9844.585000
title : 02:41:31.056
Chapter #0.32: start 9844.585000, end 9961.952000
title : 02:44:04.585
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x544, SAR 1:1 DAR 40:17,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
Stream #0:2(eng): Subtitle: text
Hopefully I got that right.
Post Thu Jan 24, 2013 3:11 pm
try to remove tis from the Viera profile to see if they play natively
<Matches container="matroska" vCodec="h264" aCodec="dca" />
Wulvor
Post Thu Feb 21, 2013 9:26 pm
Sorry I never posted a reply, I ended up going away before I could. When I got back my wife had purchased a Western Digital TV Live that was on sale, everything seems to work fine with it.
Return to Panasonic
