Problems Viera 50GT50
heero
Post Fri Mar 22, 2013 1:05 pm
Hi, I have a problem with Panasonic 50gt50 and serviio 1.2. The TV sees serviio online once out of ten, the connection is cable cat5e profile is used Panasoniv Viera 2011, I also tried the Panasonic Viera 2012 with the same result.
What could be the problem?
Thanks and sorry for my english
Post Fri Mar 22, 2013 11:02 pm
Re: Problems Viera 50GT50
Try the latest release (1.2.1) and see if it improves.
heero
Post Mon Mar 25, 2013 10:07 pm
Thanks for the help, it works better but still has some problems, it is not always seen by the server serviio tv but this time one time in four works.
Post Mon Mar 25, 2013 11:28 pm
What are you running Serviio on - a PC?, which operating system?
The purist may hate this advice but one thing you may want to try (as a work around until fixed) is running another media server on the same PC as Serviio - if using Windows simply enable streaming from Windows Media Server (see http://www.sevenforums.com/tutorials/139310-media-streaming-using-windows-media-player-turn-off.html). Once enabled your Panasonic should show two media servers - one for Windows (WMP, which you can ignore) and one for Serviio. The idea here is that the appearance of the WMP server will hold the Panasonic Media Server screen up long enough for Serviio to be detected (can take a while) and displayed.
Let me know if this helps and if it does, how long roughly it is taking for Serviio to appear.
ps. Serviio's appearance in the Pana Media Server screen shouldn't be effected by what profile you select. Stay with the Panasonic Viera G/GT/DT/UT/VT (2011/2012) profile.
heero
Post Wed Mar 27, 2013 12:53 pm
Using windows 7 Ultimate x64bit I enabled windows media player server, I can see perfectly, however serviio still has problems, does not always appear in the panasonic. The profile used is the Panasonic Viera G / GT / DT / UT / VT (2011/2012).
Return to Panasonic
