1.2.1 stuttering
geekay67
Post Sun Apr 07, 2013 2:12 pm
1.2.1 stuttering
Hi
Been a user for a couple of years now but just downloaded 1.2.1 and my panasonic has started stuttering big time. Did the usual reboots pc router etc. to no avail
Dowloaded twonky evaluation copy which was working perfectly so must conclude that 1.2.1 is the problem.
Anyone else encountered this.
Regards
Post Mon Apr 08, 2013 12:00 am
Re: 1.2.1 stuttering
Not here. Some things to look at:
  • Is it all files, or just selected ones?
  • What are your subtitle settings (Delivery tab, Subtitles in Serviio console)?
  • What profile are you using?
  • What is your PC CPU usage (and disk usage if possible) during streaming?
  • Lastly, post a detailed log to see what Serviio is doing to your files.
Post Tue Apr 09, 2013 4:59 pm
I assume it's transcoding hardsubs.
Return to Panasonic
