play music files on shared files but no on line radio
sliprock
Post Wed Nov 13, 2013 6:47 am
Have panasonic vieta TC-L55et5 that shows and plays all music files. But unable to get TV to recognize any on line radio stations. No problems seen in log file. Restarted computer, TV, and router. The radio stations were tested in VLC (worked) also show a green check mark in online sources check, live stream checked. Occassionally (2 times) the radio station showed up on TV on line under music header but stated unable to read file both times. Have tired several different stations My router is running Iv4. Been working on this 4 3 days looking at log file but no error messages that were not resolved later in the program. Believe that program is reading stations but refusing to place them in TV DNLA. I am buffaloed Got any suggestion where to look next.
Thanks for the help
Sliprock
Post Mon Dec 02, 2013 9:34 pm
Re: play music files on shared files but no on line radio
Give some examples of URLs and detailed log of playing a stream. Also which profile are you using?
sliprock
Post Sat Dec 07, 2013 9:21 pm
Thanks for responding to the question. I got this problem fixed. I dont understand why but this solution worked. I had to go back into WMP and reset the stream to all devices in the network. Apparently the WMP and Serviio on my computer running WMP 12 are having some cross communications lines. If somebody knows the answer to this I would appreciate an explanation as to how WMP solution solved this problem when both programs are supposed to be separate. I do not have Serviio running with WMP.
Thanks again for your response
Return to Panasonic
