Subtitles size on L42ET60
MikePort
Post Sun Dec 15, 2013 2:14 pm
Hello there,
I'm using Panasonic TX-L42ET60 with Serviio latest and Panasonic Viera 2013 Profile. Everything works well, including playing external subtitles.
I would like to increase my subtitles font size (usually .mkv files with external .srt). I've tried to convert to .ass format ( viewtopic.php?f=5&t=9466#p64510 ) but no luck (I'm getting font size="18" when selecting Subtitles text). Any ideas?
Thanks,
Mike
Post Tue Dec 17, 2013 1:35 pm
Re: Subtitles size on L42ET60
On the Panasonic, it usually doesn't burn-in the text into the video, so changing the ass file will not have any effect. If there is no setting in the TV's menu, you are stuck.
MikePort
Post Mon Dec 30, 2013 7:04 am
zip wrote:On the Panasonic, it usually doesn't burn-in the text into the video, so changing the ass file will not have any effect. If there is no setting in the TV's menu, you are stuck.
Then I have to watch movies from laptop to get larger subtitles. Thanks and keep up the good work with Serviio.
Return to Panasonic
