aspect ratio
rlar
Post Thu Mar 01, 2012 8:23 am
Re: aspect ratio
Illico wrote:
Scoootch wrote:BUT all these mkv are in the good ratio with Serviio through PS3
PS3 Media Server use same workaround with mencoder option to pad video into 16:9 and change DAR to 4:3
Sorry, I'm new to this world, so I'm a bit confused. I didn't get if it is a reply to my post or if it is just an observeation to the quoted post.
Post Thu Mar 01, 2012 12:47 pm
Re: aspect ratio
rlar wrote:If no alternative solution has been found to this problem I would be interested in trying the real-time transcoding. Is there a configuration file which enable this transcoding or should I try to write it down (I don't have any idea about how to do it, but I hope to be able with some effort)
For my Sony Bravia TV Aspect ratio issue, I use this solution:
viewtopic.php?f=11&t=2956&start=30#p34000
cvandeplas
Post Tue Mar 20, 2012 5:31 pm
Re: aspect ratio
This unfortunately doesn't seem to work.
PMI
Post Sat Mar 31, 2012 3:41 am
Re: aspect ratio
cvandeplas wrote:This unfortunately doesn't seem to work.
The perl script may or may not always work, but padding transcoded files to 16:9 aspect ratio DOES work, so that would be a big step forward.
It may not be a solution for all files which play with bad aspect ratios, but it works fine for movies with 2.40:1, 2.35:1, and 1.85:1 aspect ratios. We know that -
1) other DLNA servers can play these files correctly on Panasonic Viera sets,
2) Mezzmo uses ffmpeg also, transcodes these files to Mpeg-2 TS w. 16:9 aspect ratio, and plays correctly
3) files padded using ffmpeg as described below play correctly on both Sony and Panasonic sets
viewtopic.php?f=5&t=5403
So, I would say that if Mezzmo can do this using ffmpeg, good chance that Serviio could do it also, at least for files being transcoded to MPEG-2 TS format... :D
Peter
AlexAnnecy
Post Sat Apr 28, 2012 1:19 am
Re: aspect ratio
Another solution in the Viera's options menu: Turn off 16:9 Overscan (in Picture/Advanced Settings). It seems this settings is specific to DLNA inputs, so it won't affect other inputs (although I haven't tried everything). :)
rlar
Post Sat May 26, 2012 8:21 am
Re: aspect ratio
I tried to switch off the overscan option, but it didn't work for me.
stevvie
Post Wed Aug 29, 2012 12:30 pm
Re: aspect ratio
Was a fix ever found as my Panny e5b stretches loads of files in serviio that seem to play ok through Mezzmo (15 day trial at the moment)
Post Wed Aug 29, 2012 6:25 pm
Re: aspect ratio
stevvie wrote:Was a fix ever found as my Panny e5b stretches loads of files in serviio that seem to play ok through Mezzmo (15 day trial at the moment)
Could you provide information about media file ?
MagicBoy
Post Tue Sep 04, 2012 11:21 pm
Re: aspect ratio
I'm getting this problem more often since upgrading to v1.x. Doesn't occur half as often on 0.6.2 with the updated 2011 Panasonic profile.
Example file is an H.264 MKV MPEG4 AVC @ 1920x816, DTS sound and subtitles.
0.6.2 - fine
1.0.1 - incorrect aspect
Post Wed Sep 05, 2012 6:44 am
Re: aspect ratio
MagicBoy wrote:I'm getting this problem more often since upgrading to v1.x. Doesn't occur half as often on 0.6.2 with the updated 2011 Panasonic profile.
0.6.2 - fine
New aspect ratio adjust feature (DAR), is added only when transcoding is used.
So its probably because on 0.6.2, your file was delivered in native format and on 1.0.1 our file is transcoded. Could you check that ? (What is the h264 profile level?)
albie
Post Sun Apr 13, 2014 11:46 pm
Re: aspect ratio
So I've stumbled on a solution (I think). In console under the Status Tab, change the profile. Mine was on Panasonic Viera; I changed it to Phillips (2009) and it seems to work. I have tried any other profiles because it worked with the first one I tried. Hope that helps!
You might need to press the aspect button on your remote to get it to work.
Post Mon Apr 14, 2014 9:42 am
Re: aspect ratio
The Philips (2009) transcodes all MKV and MP4 files which may be an overkill depending on which model Pana you have.
In the latest (1.4.1.2) Panasonic profiles most of the cases where the video needs to be transcoded and is likely to have > 16:9 aspect ratio (ie. h264 video) have been set to pad the video to display the proper aspect ratio. The majority of problems arises when video is being remuxed.
So we are faced with a choice:
  • Transcode all [h264] video even where remuxing will suffice. This will then transcode all video even where the aspect ratio is 16:9 or 4:3 (these ratios can be remuxed fine - its only where the aspect ratio is greater than 16:9 we have a problem);
  • Stay as-is, remuxing many h264 cases, and have the user edit the profile where it is causing them grief.
The first option loads up CPU usage, and will not be welcomed by lower powered devices (eg. NAS's). The second option is causing more problems as widescreen (>16:9) video is becoming the norm. My two cents worth - I'm probably leaning toward the first option (transcode all H264 video even when remuxing would suffice) but think more discussion on this is needed.
There is a third option (and not one I necessarily favour) but it requires coding in Serviio - have a matches option for aspect ratio - eg.
<Matches container="*" vCodec="h264" vAspectGreaterThan="16:9" />
This would allow these video files to be intercepted early in the profile and the video transcoded, and later in the profile have the standard remuxing commands to pick up the rest. Once again, more discussion as I fear this would make the profiles very complex (you may end up duplicating a lot of commands, one for the >16:9 case and one for the 16:9 and below).
Post Mon Apr 14, 2014 12:32 pm
Re: aspect ratio
I had never noticed before, but my Panasonic ST30 is doing the same thing. Guess I hadn't been watching the right movies! :lol:
This is using the ST30 built-in DLNA player. When I watch the same video on the same TV using my Roku, the aspect ratio is correct. I'm sure the Roku is transcoding the file, so that's probably the difference. The movie is Star Wars IV, ripped with MakeMKV, then reprocessed with Handbrake to change the default audio track to standard DTS instead of DTS-HD Master Audio.
EDIT: Here's MediaInfo for the one I was watching:
Unique ID                                : 206512941465842168319466674862507226955 (0x9B5CF21F1D12DFAD231D372A7DF4F74B)
Complete name                            : Z:\Star Wars Episode IV - A New Hope (1977).mkv
File size                                : 9.91 GiB
Duration                                 : 2h 4mn
Overall bit rate                         : 11.4 Mbps
Writing application                      : HandBrake 0.9.9
Writing library                          : libmkv 0.6.5
TITLE                                    : A New Hope
Format profile                           : Main@L4.0
Duration                                 : 2h 4mn
Height                                   : 816 pixels
Display aspect ratio                     : 2.35:1
Writing library                          : x264 core 130 r2273 b3065e6
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : ES
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 4mn
Bit rate                                 : 1 509 Kbps
Channel(s)                               : 7 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Bit depth                                : 24 bits
Stream size                              : 1.31 GiB (13%)
Audio #2
Format                                   : DTS
Format profile                           : MA / Core
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 2h 4mn
Bit rate                                 : Unknown / 1 509 Kbps
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Text
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Menu
00:00:00.000                             : Chapter 1
00:00:21.021                             : Chapter 2
00:01:53.363                             : Chapter 3
00:04:52.793                             : Chapter 4
00:07:28.365                             : Chapter 5
00:08:54.868                             : Chapter 6
00:11:21.514                             : Chapter 7
00:15:40.231                             : Chapter 8
00:19:40.179                             : Chapter 9
00:23:33.287                             : Chapter 10
00:25:32.740                             : Chapter 11
00:27:45.622                             : Chapter 12
00:29:12.793                             : Chapter 13
00:32:34.161                             : Chapter 14
00:34:53.008                             : Chapter 15
00:36:54.212                             : Chapter 16
00:39:05.635                             : Chapter 17
00:41:42.375                             : Chapter 18
00:42:31.632                             : Chapter 19
00:44:51.731                             : Chapter 20
00:47:52.620                             : Chapter 21
00:49:57.995                             : Chapter 22
00:51:13.696                             : Chapter 23
00:52:40.741                             : Chapter 24
00:54:12.416                             : Chapter 25
00:56:59.917                             : Chapter 26
00:59:14.009                             : Chapter 27
01:03:10.829                             : Chapter 28
01:06:16.473                             : Chapter 29
01:08:21.973                             : Chapter 30
01:12:32.390                             : Chapter 31
01:14:12.657                             : Chapter 32
01:17:13.838                             : Chapter 33
01:19:09.328                             : Chapter 34
01:21:29.385                             : Chapter 35
01:25:00.304                             : Chapter 36
01:27:02.092                             : Chapter 37
01:29:56.266                             : Chapter 38
01:33:48.248                             : Chapter 39
01:36:39.961                             : Chapter 40
01:38:06.756                             : Chapter 41
01:39:37.638                             : Chapter 42
01:41:24.996                             : Chapter 43
01:42:37.526                             : Chapter 44
01:45:02.630                             : Chapter 45
01:49:42.785                             : Chapter 46
01:55:18.912                             : Chapter 47
01:57:47.394                             : Chapter 48
01:58:28.643                             : Chapter 49
02:00:14.499                             : Chapter 50
Previous
Return to Panasonic
