Panasonic tx-65ax800t
Riesling
Post Fri Jun 27, 2014 2:53 pm
anyone has experience how Serviio works with this tv ?
I tried with 4k files and the tool performs the transcoding even if the Panasonic is a 4k tv.
In Serviio tool there is only the Panasonic 2013 profile and not for this tv.
I also shared a directory with photos and the presentation is slow and does not permit to change the photo manually, I have to wait the timing of the presentation.
The only fluid reproduction is the music.
Can anyone help me ?
Thank You
Regards
Riesling
Post Sat Jun 28, 2014 12:12 pm
Re: Panasonic tx-65ax800t
No one can answer to my questions ?
The Serviio version is 1.4.1.2.
The pc is connected directly by cable to the router and the tv is connected via wifi.
For the TX-65ax800t is it correct the "Panasonic 2013" profile ?
I have difficulties with avi and mpeg4 formats.
For mpeg4 the tv shows me "not supported" and for avi after a while shows me "not readble".
The formats are supported because if I connect he HDD to the tv by usb port, it works.
Anyone can help me ?
Thank You
Regards
Post Sat Jun 28, 2014 6:39 pm
Try the Generic DLNA profile and see if either file plays. Post MediaInfo details for both files.
Return to Panasonic
