Panasonic G20 Series - audio transcoding
valhalla
Post Fri Jan 28, 2011 8:59 pm
All,
Just downloaded this yesterday. Works a treat so far! However, I just encountered an issue with a mkv where no Audio OR Video was playing. I needed to change the 'Panasonic Viera' profile slightly to transcribe DTS to AC3 after which Audio / Video were restored and works a treat. Might be an idea to change this is the next rel, I suspect most panasonics will suffer from this.
(I have a Panasonic TX-P50G20B)
Changes I made are:
Post Fri Jan 28, 2011 11:41 pm
Re: Panasonic G20 Series - audio transcoding
if you only want to trancdode dts audio, you should add that to the matcher elements, otherwise all h264 videos (no matter what audio) will be transcoded
Jagrys
Post Sun Jan 30, 2011 12:20 am
Valhalla,
There is an info in Panasonic thread about DTS problem.
valhalla
Post Mon Jan 31, 2011 10:15 am
Jagrys wrote:Valhalla,
Ah perfect, thanks. I found it eventually buried in a general panasonic thread!
I've change my panasonic pofile to:
<Matches container="matroska" vCodec="h264" aCodec="dca" />
Jagrys
Post Mon Jan 31, 2011 4:35 pm
Exactly , it worked for me either
Musick7
Post Fri Apr 15, 2011 12:22 am
valhalla wrote:All,
Changes I made are:
_________________________________________________________________________________________________
I take it the Panasonic TC-P50G20 works with Serviio...
Did you have to do anything special to make it work? I'm using Mac OS X Snow Leopard 10.6.7 able to connect using Wifi or Ethernet to my complex Network setup :|
For High Speed Internet, I've got AT&T U-Verse 18mb Download 1.5mb Upload, using the 2Wire router they supply with service, Model; 2WIRE 3800HG-B w/Wifi built in and 4 Ethernet ports.
My iMac connects to the 3800 with ethernet directly to router. I also have a 2nd wireless router attached to on of the 4 ports. This wifi router is, Apples Airport Extreme and is setup using 5GHz N only mode. Several feet away, is my 3rd Airport Extreme, it talks to the 2nd Airport through WIFI 5GHz N only.
I added a DELL PowerConnect switch to add more Ethernet ports to the 2WIRE 3800 .
Hooked to the Dell device,
Panasonic G20 TV,
DirecTV HR24-500,
HAVA network Streaming Player. ~which isn't on at the moment. Due to HAVA player only supports WINDOWS OS and I don't have Win OS.
I've had the Serviio Media Server working a few times and able to stream to my DirecTV HR24 but its sketchy at best... First day I downloaded and installed it, after a few short min. It was working great. Although no FF or RW using the directv remote or any other remote for that matter... But it Worked!
The next day, it didn't. Didn't change any settings it just wouldn't show up in the DTV Menu. After playing around with it for about 2 hours It started working again but this time, it only showed the movies and acted like it would play them but just went to a black screen and the play bar didn't start counting like it did the last time...
It hasn't worked since... Not sure what to do there...
So I wanted to try the Panasonic G20 TV. We just got the TC Board replaced today since it went out, and I'm just now getting ready to start messes with the Serviio media server to see if I can make it work...
But I don't konw for sure if it works or not so I'm here hoping someone will let me know for sure it does work.
PS
Did I post this in the right area? So far my other post hasn't been answered... :?:
Post Fri Apr 15, 2011 10:57 am
It works, make sure you select the Viera profile.
Musick7
Post Sat Apr 16, 2011 8:42 am
zip wrote:It works, make sure you select the Viera profile.
Is there a media server menu of some sort within the Panasonic TC-P50G20 menus? I'm able to see the TV in Serviio Console along with 3 other devices... Both DirecTV HR24.
If I tell serviio to use the TV IP as main device, I still can't seem to locate how to view anything using the server...
I thought it might be within the Veira Cast App area, no it's not. Not sure where or how to locate it...
Do I need to change or add anything within serviio .plist?
If so, what do I need to add?
I haven't changed anything outside of the Console area...
Also, Serviio doesn't seem to want to stream movies for me anymore on the DirecTV HR24 box... It see's the server and I can see all the movies with little Camer's next to each movie, but when I play one, it goes into black screen like its going to start playing it... but never plays anything, it acts like its on pause but It's not...
Anyone have a suggestion?
Post Sat Apr 16, 2011 11:42 am
can you post detailed log? see my signature for HOWTO
Musick7
Post Tue Apr 19, 2011 7:11 pm
command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,629 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,632 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-19 14:06:47,635 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,638 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,640 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,645 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-19 14:06:47,648 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,651 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,654 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,657 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-19 14:06:47,659 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,662 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,665 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-19 14:06:47,669 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-04-19 14:06:49,186 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-19 14:06:49,269 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.1.80, timeout = 0
2011-04-19 14:06:49,269 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b64f1ffb-b421-3631-a8dd-ac424be3dbf7
2011-04-19 14:06:51,073 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-04-19 14:06:59,855 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-04-19 14:06:59,855 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-19 14:06:59,856 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-04-19 14:06:59,856 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-19 14:06:59,857 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/Harlan/Movies/DivX Movies
2011-04-19 14:06:59,858 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: /Users/Harlan/Movies/DivX Movies
2011-04-19 14:06:59,859 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2011-04-19 14:06:59,889 DEBUG [LibraryAdditionsCheckerThread] Found file 'Age of the Dragons.avi', checking if it's already in the Library
2011-04-19 14:06:59,889 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Age of the Dragons.avi
2011-04-19 14:06:59,942 DEBUG [MediaItemDAOImpl] Media item Age of the Dragons.avi already exists in DB
2011-04-19 14:06:59,963 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fair Game Part 1.mov', checking if it's already in the Library
2011-04-19 14:06:59,963 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fair Game Part 1.mov
2011-04-19 14:06:59,964 DEBUG [MediaItemDAOImpl] Media item Fair Game Part 1.mov already exists in DB
2011-04-19 14:06:59,985 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fair Game Part 2.mov', checking if it's already in the Library
2011-04-19 14:06:59,985 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fair Game Part 2.mov
2011-04-19 14:06:59,986 DEBUG [MediaItemDAOImpl] Media item Fair Game Part 2.mov already exists in DB
2011-04-19 14:07:00,006 DEBUG [LibraryAdditionsCheckerThread] Found file 'I Am Number Four.avi', checking if it's already in the Library
2011-04-19 14:07:00,007 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item I Am Number Four.avi
2011-04-19 14:07:00,008 DEBUG [MediaItemDAOImpl] Media item I Am Number Four.avi already exists in DB
2011-04-19 14:07:00,028 DEBUG [LibraryAdditionsCheckerThread] Found file 'Just Go with It.avi', checking if it's already in the Library
2011-04-19 14:07:00,028 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Just Go with It.avi
2011-04-19 14:07:00,029 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2011-04-19 14:07:00,031 DEBUG [MediaItemDAOImpl] Media item Just Go with It.avi already exists in DB
2011-04-19 14:07:00,051 DEBUG [LibraryAdditionsCheckerThread] Found file 'Love and Other Drugs.avi', checking if it's already in the Library
2011-04-19 14:07:00,051 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Love and Other Drugs.avi
2011-04-19 14:07:00,052 DEBUG [MediaItemDAOImpl] Media item Love and Other Drugs.avi already exists in DB
2011-04-19 14:07:00,057 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-04-19 14:07:00,058 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-04-19 14:07:00,059 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2011-04-19 14:07:00,061 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor EMBEDDED
2011-04-19 14:07:00,073 DEBUG [LibraryAdditionsCheckerThread] Found file 'No Strings Attached.avi', checking if it's already in the Library
2011-04-19 14:07:00,073 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item No Strings Attached.avi
2011-04-19 14:07:00,073 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,075 DEBUG [MediaItemDAOImpl] Media item No Strings Attached.avi already exists in DB
2011-04-19 14:07:00,095 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sanctum.avi', checking if it's already in the Library
2011-04-19 14:07:00,096 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Sanctum.avi
2011-04-19 14:07:00,097 DEBUG [MediaItemDAOImpl] Media item Sanctum.avi already exists in DB
2011-04-19 14:07:00,117 DEBUG [LibraryAdditionsCheckerThread] Found file 'Season of the Witch.avi', checking if it's already in the Library
2011-04-19 14:07:00,117 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Season of the Witch.avi
2011-04-19 14:07:00,118 DEBUG [MediaItemDAOImpl] Media item Season of the Witch.avi already exists in DB
2011-04-19 14:07:00,139 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Dilemma.avi', checking if it's already in the Library
2011-04-19 14:07:00,139 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Dilemma.avi
2011-04-19 14:07:00,140 DEBUG [MediaItemDAOImpl] Media item The Dilemma.avi already exists in DB
2011-04-19 14:07:00,160 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Mechanic.avi', checking if it's already in the Library
2011-04-19 14:07:00,160 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Mechanic.avi
2011-04-19 14:07:00,161 DEBUG [MediaItemDAOImpl] Media item The Mechanic.avi already exists in DB
2011-04-19 14:07:00,174 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2011-04-19 14:07:00,175 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor EMBEDDED
2011-04-19 14:07:00,176 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,182 DEBUG [LibraryAdditionsCheckerThread] Found file 'Tron .avi', checking if it's already in the Library
2011-04-19 14:07:00,182 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Tron .avi
2011-04-19 14:07:00,183 DEBUG [MediaItemDAOImpl] Media item Tron .avi already exists in DB
2011-04-19 14:07:00,203 DEBUG [LibraryAdditionsCheckerThread] Found file 'UnThinkable.avi', checking if it's already in the Library
2011-04-19 14:07:00,203 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item UnThinkable.avi
2011-04-19 14:07:00,204 DEBUG [MediaItemDAOImpl] Media item UnThinkable.avi already exists in DB
2011-04-19 14:07:00,205 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2011-04-19 14:07:00,276 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2011-04-19 14:07:00,278 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor EMBEDDED
2011-04-19 14:07:00,279 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,380 DEBUG [MediaItemDAOImpl] Getting file of media item 16
2011-04-19 14:07:00,381 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 16) and extractor EMBEDDED
2011-04-19 14:07:00,381 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 16) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,482 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-04-19 14:07:00,483 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2011-04-19 14:07:00,484 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,585 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2011-04-19 14:07:00,586 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2011-04-19 14:07:00,587 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,687 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2011-04-19 14:07:00,688 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2011-04-19 14:07:00,689 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,790 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2011-04-19 14:07:00,791 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2011-04-19 14:07:00,792 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,893 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2011-04-19 14:07:00,894 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2011-04-19 14:07:00,895 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:00,996 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2011-04-19 14:07:00,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2011-04-19 14:07:00,998 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:01,074 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.81, timeout = 0
2011-04-19 14:07:01,075 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b64f1ffb-b421-3631-a8dd-ac424be3dbf7
2011-04-19 14:07:01,098 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2011-04-19 14:07:01,100 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2011-04-19 14:07:01,100 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:01,201 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2011-04-19 14:07:01,202 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor EMBEDDED
2011-04-19 14:07:01,203 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:01,303 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2011-04-19 14:07:01,304 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor EMBEDDED
2011-04-19 14:07:01,305 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor COVER_IMAGE_IN_FOLDER
2011-04-19 14:07:01,305 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2011-04-19 14:07:01,345 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2011-04-19 14:07:02,879 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.1.80, timeout = 0
2011-04-19 14:07:02,879 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b64f1ffb-b421-3631-a8dd-ac424be3dbf7
2011-04-19 14:07:04,684 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:29
2011-04-19 14:08:33,843 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.81, timeout = 0
2011-04-19 14:08:33,843 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b64f1ffb-b421-3631-a8dd-ac424be3dbf7
2011-04-19 14:08:35,647 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.1.80, timeout = 0
2011-04-19 14:08:35,647 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b64f1ffb-b421-3631-a8dd-ac424be3dbf7
2011-04-19 14:08:37,451 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:27
Musick7
Post Tue Apr 19, 2011 7:12 pm
There is more than that but said it was over the amount allowed to post by a few hundred thousand...
Post Wed Apr 20, 2011 8:52 am
NOthing useful in this part of the log. You can zip it up and attach.
Musick7
Post Wed Apr 20, 2011 5:31 pm
zip wrote:NOthing useful in this part of the log. You can zip it up and attach.
Is this the right Log?
If so I'll attach the whole log if so.
Musick7
Post Wed Apr 20, 2011 7:02 pm
Here is the zipped log.
Serviio Log info.zip
Serviio Log zipped
(25.54 KiB) Downloaded 1064 times
Post Wed Apr 20, 2011 7:42 pm
I doubt 10.0.1.2 is your IP address. Put your proper IP into the Bound IP address field. I think you installed Parallels or similar virtualizing software which might also block/ameng the way your network interfaces work.
Musick7
Post Thu Apr 21, 2011 4:19 am
zip wrote:I doubt 10.0.1.2 is your IP address. Put your proper IP into the Bound IP address field. I think you installed Parallels or similar virtualizing software which might also block/ameng the way your network interfaces work.
My Applre Airport extreme Had a 10.0.1.2 address... Now it's in the 192.168.1.65+ area.
Hmm... That is odd you see 10.0.1.2 because I've had it set to 192.168.1.88 for the living rm. Directv HR24 for a couple weeks now, since i haven't been able to use it I haven't changed anything.
As of right now I have 3 devices showing up, One is the Panasonic Veira G20 TV and the 2 others are the DirecTV HR24's All items have a 192. IP next to them. In the binding IP area I've got it set to 192.168.1.88 which is living rm DTV.
Where do I change the 10.0.1.2 at?
Post Thu Apr 21, 2011 8:44 am
Sorry, you're right. The 10.x.x.x IP was from 10- days ago, the latest is this:
[Device] Created UPnP Device with UUID: b64f1ffb-b421-3631-a8dd-ac424be3dbf7, bound address: 192.168.1.88
Serviio msends multicast on this I but no requests are coming back. That could be caused by:
- firewall blocking 8895
- Parallels blocking some of the ports or making the OS to use wrong network interfaces
Musick7
Post Fri Apr 22, 2011 5:29 am
zip wrote:Sorry, you're right. The 10.x.x.x IP was from 10- days ago, the latest is this:
I don't have Parallels software installed on this iMac... nor Windows on another partition.
I do have, a few iPhone App's that use VPN/VNC to remote access my mac from iPhone. I also have my Mac Screen sharing for my internal network turned on to access either iMac or Macbook Pro within the network.
I went in to my 2wire router and made sure port 8895 was open on my iMac.. it is.
Musick7
Post Sat Apr 23, 2011 9:53 pm
So I got Serviio to work again... I deleted iSadora.app which was installed from the beginning... I deleted iSadora 2 days ago and restarted Serviio. It worked almost instantly. Watched Smallville last night through the DirecTV HR24 and all went well. (Still no FF or RW)
Today, tried to watch a movie, and it shows up and has all the movies within the folder with Cameras next to each one, but when I click play on any of them, it goes to the movie but just goes black screen... never starts playing.
Back to square one.... :cry:
Musick7
Post Sat Apr 23, 2011 11:36 pm
Since last night, Nothing has changed... It worked great, However I couldn't view anything on my sec. hr24 directv receiver. I could see all the content there but it wouldn't play either. The only thing that changed was the iMac went to sleep after no use like normal.
No other software like serviio is running or installed. The only thing installed that is a server would be Remote Tap iphone app for vnc, Splashtopremote for iphone, everyAir Server for iphone, PS3 Media Server... which has been installed from day 1. This is Sony's Server software,
And that it for server stuff...
I actually forgot about that one.
Any suggestions?
Return to Panasonic
