Panasonic Bluray BDT230 "Cannot play" error
freaknik
Post Thu Mar 27, 2014 2:21 pm
Hi, first post and I searched first but haven't been able to get Serviio to play any videos of any kind on my bluray.
It sees the server, browses to the files, sees all the files, but if I click on one, any format, it always says cannot play.
The vids work fine on the player through network share.
Same videos play through Serviio perfectly to an android app on a phone.
In the Serviio console, my bluray shows up as unrecognized device.
Even if I change profiles to the Panasonic BD Player one it does the same thing, cannot play.
Is it possible to play Serviio videos on a BDT230?
I read in these boards that a custom profile could help but I have no idea how to make one.
Thanks in advance for any help, I would love to use Serviio on my TV through the btd230 player.
EDIT: Here is the media info for an example of a video I am trying to play:
Menu ID                                  : 1 (0x1)
Format profile                           : High@L3.0
Codec ID                                 : 27
Duration                                 : 1s 680ms
Width                                    : 768 pixels
Height                                   : 432 pixels
Frame rate mode                          : Variable
Menu ID                                  : 1 (0x1)
Format version                           : Version 4
Muxing mode                              : ADTS
Codec ID                                 : 15
Duration                                 : 2s 948ms
Sampling rate                            : 44.1 KHz
Delay relative to video                  : -193ms
freaknik
Post Fri Mar 28, 2014 6:15 am
Re: Panasonic Bluray BDT230 "Cannot play" error
Fixed it by replacing ffmpeg with a newer one. Loving this program!
Return to Panasonic
Users browsing this forum: Google [Bot] and 1 guest
