Panasonic BluRay issues
QualTech
Post Thu May 22, 2014 5:12 pm
Server software works pissa!
Only problem is that the video will not resume play after pause. Anyone have a suggestion?
Quaddy1
Post Sun Jun 08, 2014 4:33 am
Re: Panasonic BluRay issues
I have the same issue with Panasonic Blu-ray player DMP-BDT220.
You can pause, and stop, but not resume play after you have paused.
Edit: I have resolved by going into settings on the Blu-ray player, and setting up a network drive, so now browse the shared computer folders directly rather than use Serviio. I can play / pause / FF etc on all media files now, with no issues.
Only prob now is subtitles, if they are in a separate file.
Return to Panasonic
