Panasonic Viera (2013) - TX-L55WTW60 won´t play Handy Video
peter1212
Post Tue Mar 24, 2015 5:36 pm
Model: Panasonic TX-L55WTW60
I have used the "Panasonic Viera (2013)" profile in the last time.
Now I bought a new handy and the TV can´t play HD videos from handy rear camera.
Videos of the front camera are working. Can you help me what I need to adjust to make it work ?
Post Wed Mar 25, 2015 12:54 pm
Re: Panasonic Viera (2013) - TX-L55WTW60 won´t play Handy Vi
Could be a few things - the different H264 profiles, or the different resolution or the frame rates for example.
Try forcing the file to be transcoded:
  • Using your favourite text editor (hint: Notepad++) edit the file Serviio\config\profiles.xml;
  • Find the Panasonic Viera (2013) profile;
  • Add the following bit in red in the region shown:
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
      <Matches container="*" vCodec="h264" profile="high_10" />
      <Matches container="*" vCodec="h264" profile="baseline" levelGreaterThan="4.1" />
      <Matches container="*" vCodec="h263" />
  • Save the file and then restart you PC.
  • Test your maverick file
This will force your baseline L5.1 file to be transcoded. If that doesn't work we may need to limit the resolution.
peter1212
Post Wed Mar 25, 2015 1:41 pm
thx for you reply
I have the proposed changes done - but without success
on the screen is all the time " please wait " and then " File is not readable"
I have noticed that my multicore cpu - windows computer runs up to 100 %
he does the transcoding but apparently it does not work.
he only transcodes the entire file ? or on the fly ? What can I do next?
Post Mon Mar 30, 2015 4:18 am
Try changing the line:
in the above to:
    <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxHeight="720" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
The above change will limit the frame hight to 720 pixel. If that still doesn't work, try maxHeight="720" maxVBitrate="14000" which will also limit the bit rate.
peter1212
Post Thu Apr 02, 2015 11:56 am
Thanks again for your help.
Too bad....
unfortunately this does not work for me.
I get always the message "This file is not supported!"
Transcoding is enabled.
Where can I check if that transcoding is working?
Post Tue Apr 07, 2015 10:18 am
You can normally tell as your CPU usage will be very high while transcoding - otherwise you can also tell by looking at a detailed log or by monitoring your temporary file (the folder listed on the Delivery, Transcoding tab of Serviio console).
You may have to re-encode the files using something like XMedia Recode to a more standard resolution/frame rate.
peter1212
Post Mon Apr 13, 2015 1:40 pm
Hi!
After a test session i can confirm the trancoder is working, but what about the handy video´s?
Return to Panasonic
