TX-40CS630E burned-in subtitles not working
Torgill
Post Mon Oct 26, 2015 2:00 pm
Hello
So I've downloaded some movies with burned-in subtitles. And I can't seem to get them working.
I have tried to enable all subtitle option.
- Enable subtitles
- Enable extraction of subtitles embedded in video files
- Enable burned-in subtitles (always)
And I have tried with only - Enable subtitles
It seems my tv supports subtitles, but when I select the language. Still no subtitles.
Thanks in advance.
Post Thu Dec 03, 2015 11:13 am
Re: TX-40CS630E burned-in subtitles not working
Which profile is being used?
Doesn't sound right - most files won't have them burnt in already - are they embedded or as a separate file (eg. a .srt file).
If embedded (or you're not sure) then please post MediaInfo for the file (see signature).
If separate, is the filename of the sub file exactly the same (other then the file extension) as the filename of the movie?
vibreaza
Post Wed Dec 16, 2015 3:30 pm
Maybe press the STTL button? It's one that's shows some characters ending with a :).
It should say subtitles on/off. That worked for me.
Cheers
Return to Panasonic
