Panasonic SC-BTT190 blu ray player
EnigmaPrime
Post Wed Dec 19, 2012 8:41 pm
Okay very new to Serviio
Has anyone tried this with Panasonic SC-BTT190 blu ray player, I can see the serviio server via the Panasonic SC-BTT190 and I can play some files, but .mkv files will not play, I can also see the online items i.e. RSS feeds, but when I attempt to play them they will not.
I am connected via Ethernet cable not WiFi.
Running windows 7, the Panasonic SC-BTT190 plays all my files via DLNA server with out any problems, I specifically want this for streams from the net via my PC to the player.
(Please note this is while using the built in DLNA server option on the player itself and not with Serviio)
Any beginner help much appreciated.
I have tried all 3 Panasonic Viera settings and the Generic setting.
EnigmaPrime
Post Wed Dec 19, 2012 9:02 pm
Re: Panasonic SC-BTT190 blu ray player
Adding more info as I read thru the forums, so please bare with me as I am on the lower end of the learning curve here.
DeviceSpy
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_LPCM_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_X_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_LPCM_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_X_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/mpeg:*,http-get:*:video/mp4:*,
http-get:*:video/quicktime:*,
http-get:*:image/jpeg:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*
EnigmaPrime
Post Wed Dec 19, 2012 9:21 pm
MediaInfo for two files.
First file plays, second file does not.
File 1 was re-encoded from a .mkv file to a .mp4 file
File 2 is in its original .mp4 format
(I thought this might be relevant)
Has this something to do with the Trans-coding which I have just started to read up on?
File 1
Complete name                            : E:\Video\Movies\Tron Legacy.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 1.42 GiB
Duration                                 : 2h 5mn
Overall bit rate                         : 1 624 Kbps
Encoded date                             : UTC 2011-03-04 04:15:45
Tagged date                              : UTC 2011-03-04 04:15:45
Writing application                      : Lavf54.36.100
Format profile                           : Main@L5.1
Format settings, ReFrames                : 1 frame
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 2h 5mn
Bit rate                                 : 1 500 Kbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.030
Stream size                              : 1.30 GiB (92%)
Writing library                          : x264 core 129 r2230
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=hex / subme=4 / psy=1 / psy_rd=2.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=230 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=0 / bitrate=1500 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=24000 / vbv_bufsize=24000 / nal_hrd=none / ip_ratio=1.40 / aq=1:2.00
Codec ID                                 : 40
Duration                                 : 2h 5mn
Duration_LastFrame                       : -11ms
Bit rate                                 : 128 Kbps
Sampling rate                            : 44.1 KHz
Stream size                              : 114 MiB (8%)
File 2
Complete name                            : E:\Video\Movies\Love.mp4
Codec ID                                 : isom
File size                                : 1.35 GiB
Duration                                 : 1h 23mn
Overall bit rate                         : 2 300 Kbps
Encoded date                             : UTC 2012-11-28 18:22:21
Tagged date                              : UTC 2012-11-28 18:22:21
Format profile                           : High@L4.0
Format settings, ReFrames                : 3 frames
Codec ID                                 : avc1
Duration                                 : 1h 23mn
Bit rate                                 : 2 206 Kbps
Maximum bit rate                         : 33.4 Mbps
Bits/(Pixel*Frame)                       : 0.044
Stream size                              : 1.29 GiB (96%)
Writing library                          : x264 core 125 r2200 999b753
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=2 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2206 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2012-11-28 18:22:45
Codec ID                                 : 40
Duration                                 : 1h 23mn
Bit rate                                 : 92.0 Kbps
Maximum bit rate                         : 102 Kbps
Stream size                              : 55.2 MiB (4%)
Encoded date                             : UTC 2012-11-28 18:22:44
EnigmaPrime
Post Wed Dec 19, 2012 9:23 pm
Have just confirmed .avi and xvid play okay
computerguy7
Post Fri Dec 28, 2012 8:06 pm
I have similar issues viewtopic.php?f=13&t=8500
LPZ_INC
Post Sun Jan 20, 2013 4:46 pm
I have a Panasonic SC-BTT195 blu ray player and used the setting on the drop down menu for Panasonic Vierra E/S/ST/VT (2011) and it worked fine. pause, ffwd, rewind. Hope this helps.
danicorleone
Post Thu Feb 28, 2013 10:33 pm
Hi all,
I was wondering if you guys were able to use or create a different profile for the BTT190.
I'm using the Panasonic Viera 2010 profile and so far I'm able to play MKV files, but no subtitles are shown, and when I try to fast forward or something, the image freezes and have to exit the movie.
Any help would be appreciated.
Regards,
tarnend
Post Tue Mar 10, 2015 12:39 am
has anyone got a btt190 to play .mkv files and be able to pause them, forward and rewind them as well? as I can play them ok but it doesn't resume when paused or try to fast forward or rewind them....
Return to Panasonic
