Serviio 1.8.32 removed if Serviio 1.8.64 install attempted
DEJ710
Post Tue Mar 28, 2017 9:22 am
Hi zip,
Inadvertently tried to update Serviio to 1.8.64 from the QNAP 4.3 install section, which failed and trashed my Serviio 1.8.32 installation and also broke the JRE 8.101 link. This shouldn't be able to happen should it?
Was forced to reinstall Serviio.
Post Tue Mar 28, 2017 2:43 pm
Re: Serviio 1.8.32 removed if Serviio 1.8.64 is installed
they are both the same, only for 64bit vs 32 bit (incl 64bit ffmpeg). Not sure what happened, but generally QNAP test these scenarios when I publish the package.
RMcV
Post Wed Apr 19, 2017 1:07 pm
Re: Serviio 1.8.32 removed if Serviio 1.8.64 install attempt
@ DEJ710
It could be that Serviio 1.8.64 (64-bit) overwrites some files that are common to Serviio 1.8.32 (32-bit), breaking it.
I don't think Serviio 1.8.32 (32-bit) will work with JRE 1.8.101 (64-bit). Just update the OS to 4.3.., install JRE 1.8.101, uninstall Serviio 1.8.32 (32-bit) and install Serviio 1.8.64 (64-bit). Configure Serviio, let it catalogue your media and then enjoy!
DEJ710
Post Sun Apr 23, 2017 12:21 am
@RMcV
Thanks for your response.
I updated to qts 4.3.3, JRE 8.101 and Serviio 1.8.64 last night and here's what I did:
1. Update to qts 4.3.3
2. Update JRE to 8.101
3. Upgrade Serviio to 1.8.64 (Install over the top) using download from serviio download link
Serviio is still functioning and my library is still in tact
