Service always stopp on synology DS18play (armv8?)
kampfdackel
Post Mon Nov 13, 2017 12:47 pm
I installed the Java8 Package from Synology and then Serviio. both installation installed well, but when i start serviio it stopps after a few seconds. if I´m fast enough i can connect from firefox but i see not much.
sorry about my englih :-). Maybe some Screenshots are helpful.
If i prepared deinstall java from synology and try to intall the java SE Embedded 8 from patters I get the error: Java binary bundle not found. i was expecting the file /volume1/public/ejdk-8u252-linux-armv6-vtp-hflt.tar.gr. .......
is there a problem with ds218play (armv8?)
Thanks a lot for your help.
Post Mon Nov 13, 2017 12:57 pm
Re: Service always stopp on synology DS18play (armv8?)
Please post a copy of the Serviio log. It sounds like something isn't starting correctly, and the log should state what it is.
I'm unfamiliar with NAS installations, so I can't say exactly where the log can be found. But where ever Serviio is installed, there should be a subfolder labeled Log and you will find it there.
neo2
Post Fri Dec 29, 2017 9:12 pm
I have the same problem
LOG
Post Fri Dec 29, 2017 10:30 pm
Neo, that is a rather small portion of the log, but my guess is that it can't find Java on your NAS. I can't help with installing Java, but that looks like the issue.
Sniffi
Post Sat Dec 30, 2017 6:52 pm
Similar Problem on DS916+
hudriwudri
Post Sun Dec 31, 2017 8:22 am
looks like it'S the same problem on the DS418j
as i described http://forum.serviio.org/viewtopic.php?f=14&t=24238 here
by(e)
Hudriwudri
ราปิด เวียนนา คือ ที่หนึ่งของฟุตบอลออสเตรีย
patters
Post Thu Feb 22, 2018 12:25 am
Java and Serviio packages updated with proper 64bit ARM support now. Please test.
This should fix OP's issue. The other poster with the DS418j has another separate issue in which the Java runtime seems fundamentally flawed on those Armada SoC systems. It appears to run fine for a few minutes then will just throw an exception almost at random. I have no cure for that unfortunately, and spent a while testing stuff on one of those units with zero success.
Users browsing this forum: Baidu [Spider] and 10 guests
