Post Tue Jul 23, 2019 5:22 pm
Can't install Serviio plugin on Synology DS918+
Just updated DSM to 6.2.2-24922 update 2. Never installed Serviio plugin before on my DS918+
Failing to install Java SE Embedded 8 which is a pre-req for Serviio plugin 2.0.0-0037.
I created the public folder since I'm multi-bay, r/w access to all accounts.
Downloaded jre-8u221-linux-x64.tar.gz from Oracle and copied it to public folder.
Added packages.pcloadletter.co.uk to DSM package sources, etc. Ran Java SE install from Community.
I received this error that it can't find the Java bundle:
But this is the exact location the file exists:
I don't see any difference between the required path/file and the existing path/file.
Any help?
