PACKAGE: Synology NAS - Serviio 2.1 Installer ***BETA***
kittmaster
Post Thu Sep 16, 2021 11:29 am
Re: PACKAGE: Synology NAS - Serviio 2.1 Installer ***BETA***
The only current solution is to remain on version 6.2 and not update to version 7.
However, some people are reporting that they can use "Docker" and set it up within that environment on Version 7 and it appears to "work".
I personally have not tried it so I can't speak to the results but you can read through the several threads here to see how it went.
tmtd
Post Thu Sep 16, 2021 11:37 am
Ah ok, so all the troubles (including what seiriostg report in the previous posts) are correlated of DSM 7.0 and not to anything else?
And also... for what you know, all the recent Synology NAS arrive with DSM 6.2 installed or DSM 7.0?
kittmaster
Post Thu Sep 16, 2021 12:15 pm
tmtd wrote:Ah ok, so all the troubles (including what seiriostg report in the previous posts) are correlated of DSM 7.0 and not to anything else?
Yes, DSM 7 is the problem, been running on 6.2 for a while and 100% stable. They changed the root privilege structures for program access. Serviio relies on that to function up until they made the change in 7....now Serviio must somehow retool the whole thing to work without root privileges.....not a small task I'm guessing.
The 2nd question....my system is a DS918+, it came with 6. Since 7 is "relatively" new....I'm only "guessing" that it "should" come with 6, but anything minted recently or from them....I would bet is version 7....but don't hold me to that.
There are tutorials out there that show you how to downgrade to 6.2....I've never done it (check YouTube or Google it), but something you could review to see if it changes how you approach the hardware purchase.
tmtd
Post Thu Sep 16, 2021 12:40 pm
I will ask to Synology support about DS-720+ and i will let you know.
Thank you for you kindness and accurancy about replies.
tmtd
Post Thu Sep 16, 2021 1:15 pm
This is the answer:
We purchasing a new NAS and doing the initial set up, DSM 7 will be installed.
And if i ask if i can downgrade:
"No, it is not advisible to update to a previous version of DSM"
ravimehta
Post Sat Oct 02, 2021 8:32 am
gege094
Post Mon Jan 17, 2022 8:36 am
Hello I have serviio, the latest generation, everything is installed but every time a film is released, I am told "Impossible to read the media"
kittmaster
Post Mon Jan 17, 2022 12:36 pm
gege094 wrote:Hello I have serviio, the latest generation, everything is installed but every time a film is released, I am told "Impossible to read the media"
What version of DSM is on your NAS? 6.2 or 7.01?
rgill90
Post Fri Feb 04, 2022 10:36 am
Hello
I'm trying to install on a DS212j, DSM 6.2 - i downloaded the package file, pointed to it on my local PC after clicking "manual install" in DSM package manager and I get this error:
"Port Undefined configured for this package is either used by another service or reserved for system use. Please disable or modify the conflicting service, or conact the developer to modify the package configration."
Is that a known issue?
Thanks in advnace!
rgill90
Post Fri Feb 04, 2022 11:05 am
ah - fixed.
it's when the package isn't removed properly
logged in as root:
rm -rf /var/packages/serviio
rm -rf /usr/local/etc/services.d/Serviio.sc
and go again.
Cheers!
Previous
