Serviio Pro problem Qnap last firmware 16 sept 2022
Muttetjeff
Post Fri Sep 16, 2022 6:39 pm
Hello
Today I updated my Qnap TS-253D nas. The firmware version is 5.0.1.2145. After the update the nas does not allow Serviio pro to start (Version 2.2.1, JRE version 8.151.2.3)
The nas message is (App Center Failed to start Serviio. QTS does not support this Serviio version. Check for updates in App Center or on the official app website).
Do I have to wait for an update, because the reinstallation does not work...
Excuse me for my english I use google translate... :)
Post Fri Sep 16, 2022 7:15 pm
Re: Serviio Pro problem Qnap last firmware 16 sept 2022
Your English translation was fine :D
Unfortunately, recent updates on many NAS devices has broken Serviio functionality. And the other issue is that Serviio itself does not create the NAS versions. They are maintained by other users, and updates are provided on the Serviio web page. The QNAP failure is I believe fairly recent, so whomever maintains that version will hopefully be working on a fix.
Muttetjeff
Post Fri Sep 16, 2022 7:32 pm
Many thanks for the quick response,
I will wait for a future update :P
Muttetjeff
Post Sat Sep 17, 2022 9:46 pm
See here for a fix with ssh command line.
viewtopic.php?f=14&t=30245&p=135118#p135118
No need to uninstall Serviio
Thanks a lot you save me :lol:
Users browsing this forum: Baidu [Spider] and 10 guests
