Missing folder within Series
pilothaz
Post Wed Jun 29, 2011 3:57 pm
I know that when you have tvshows added on SickBeard and there is no episodes captured that the folder will not show within the Series folder. My issue is when I have stuff within the folder and Season folders but it isn't showing up in the Series folder.
The program is Tosh.0
Folder is labelled as this: /mnt/thedrive/media/tvshows/Tosh.0/Season 2/ but I do not see Tosh.0 at all when I look through Series. The only way to see the folder is either enable Folders for browsing through or Titles.
I love how you have the Movies and Series and would just like to keep using these exclusively. Can you think of a way to have this folder 'appear'? I have also tried renaming the Tosh.0 to Tosh_0 but that didn't work.
Thanks in advance,
Haz
Cheer's and Beers.
Post Wed Jun 29, 2011 4:05 pm
Re: Missing folder within Series
what's the file name?
pilothaz
Post Wed Jun 29, 2011 4:11 pm
zip wrote:what's the file name?
titles are these which SickBeard renamed. Please See image as well as locations.
Post Wed Jun 29, 2011 4:14 pm
I always verify all my series names on http://www.thetvdb.com and if there are spaces in the name I put the files in a folder with the series name.
Post Wed Jun 29, 2011 4:17 pm
check detailed log to see what series name is serviio using for the tvdb.com lookup
pilothaz
Post Wed Jun 29, 2011 4:19 pm
All of them should be correct as it is done through SickBeard when adding a show.
As seen here.
pilothaz
Post Wed Jun 29, 2011 4:23 pm
zip wrote:check detailed log to see what series name is serviio using for the tvdb.com lookup
Where is that? I cannot use the console at this time as I am at work. through ftp i can pull the serviio.log file.
Post Wed Jun 29, 2011 4:31 pm
Serviio will change the file name a bit when it makes the search request. One of the things - it removes any dots from the file name so you'll end up with 'tosh o' which doesn't return any results on thetvdb.com. The only help now is to edit the record on thetvdb.com and add another alternative name to it (e.g. 'Tosh O'), it already has a few, so that it matches the search.
pilothaz
Post Wed Jun 29, 2011 4:42 pm
Thanks for the quick replies. Where are you seeing the alternative names? I have tried to register but haven't gotten an email confirmation from them for some reason.
One last thing to this I guess is how do you know it is a Series - I had for some reason in Movies section some Chapelle's Show icons so some shows were placed in there. Is it based on length, or that there is multiple ones of it? Or does it all get based upon the thetvdb.com
pilothaz
Post Wed Jun 29, 2011 4:44 pm
pilothaz wrote:Thanks for the quick replies. Where are you seeing the alternative names? I have tried to register but haven't gotten an email confirmation from them for some reason.
Nevermind I found it.
pilothaz
Post Wed Jun 29, 2011 4:50 pm
This is from thetvdb.com website on the Aliases....
http://forums.thetvdb.com/viewtopic.php?f=4&t=6508
posted May 9th, 2011
Aliases aren't supported in the API yet, so no flexget shouldn't be seeing it.
