DS211+ - console
maximizor
Post Sat Sep 01, 2012 5:38 pm
DS211+ - console
Hey,
installed Serviio/java, in packages center it's showing as running. When I acces the IP:23424/mediaserver, i'm getting the login. Stating that I have not set the password in the console. Except in the packagecenter the console is not showing up anywhere. How do I activate it?
Greetings Max
Post Sat Sep 01, 2012 7:00 pm
Re: DS211+ - console
I don't think one is included by default any more. Either follow http://www.serviio.org/component/conten ... e?id=21#q2 and install the console on your pc, use ServiiDroid, or use the PHP webui which mostly supports 1.0.
