Need Help: Installing on DNS-320 NAS
coolgc
Post Fri Aug 12, 2011 1:04 pm
I just bought a NAS (D-link Model DNS-320). I am totally new to using a NAS. It's media server is not transcoding some video files for me when I play them on the PS3 media player. I would like to install Serviio on this NAS. Can one of you experts please walk me through the steps to install it on DNS-320?
I appreciate help!
Thank you!
coolgc
Post Thu Aug 18, 2011 11:37 pm
Re: Need Help: Installing on DNS-320 NAS
Can someone please help and answer? I searched the forum and couldn't find the installation instructions for a D-Link in a straightforward manner. Thank you.
mcjeff2002
Post Fri Aug 19, 2011 10:20 am
first, Have you got SSH access on your NAS ?
Jeff
dascoobmaster
Post Mon Aug 22, 2011 11:05 pm
I did start looking at this and it may be a goer....
see here -> viewtopic.php?f=14&t=1945&start=10
The first step is getting the JRE running. but I guess it depends on which device you are streaming to and how much CPU you need.
BlDsT
Post Sat Aug 27, 2011 3:27 pm
coolgc wrote:Hello,
I appreciate help!
Thank you!
I managed to run serviio on my DNS-320 so if you haven't installed it already I could write a little howto.
extenue
Post Thu Oct 06, 2011 8:13 pm
hi guyz,
for all of you who have installed Serviio on dns 320 , after a fresh reboot of your dlink , how many CPU java is taking ? for me it's 90% so i have issue , i think 90% is too high
is anyone is aware of this prob ?
i used this tuto for having serviio running : viewtopic.php?f=14&t=3122
thanks exté
Post Sun Oct 09, 2011 4:33 pm
it's either updating your library or transcoding a movie
TechRomeo
Post Sun Jul 15, 2012 12:03 pm
I installed Serviio 0.6.1 following instructions on the forum. All worked well on my DNS 320 with a Samsung D series TV. I control it with ServiDroid console on my Mobile Phone. I then upgraded to Serviio 0.6.2 since resume did not work well with my Samsung TV. Upgrading was a tourture since even a simple copy / paste is hard if you are not familiar with Linux. I managed to deleted the /opt/serviio folder since I could not paste over the top of it. I replaced it with a new /opt/serviio with 0.6.2. inside. However Serviio did not start when I rebooted the NAS. Serviio 0.6.2 works well when I start it with Putty SSH client using the sh serviio.sh command. However the moment I stop the Putty SSH, then Serviio server stops too. Did I delete something too much when I deleted the original /opt/serviio directory? Or is there a new install with Debian Squeeze + Serviio 0.6.2. to solve this. :
galinhola
Post Sat Sep 08, 2012 4:02 pm
TechRomeo wrote:I installed Serviio 0.6.1 following instructions on the forum. All worked well on my DNS 320 with a Samsung D series TV. I control it with ServiDroid console on my Mobile Phone. I then upgraded to Serviio 0.6.2 since resume did not work well with my Samsung TV. Upgrading was a tourture since even a simple copy / paste is hard if you are not familiar with Linux. I managed to deleted the /opt/serviio folder since I could not paste over the top of it. I replaced it with a new /opt/serviio with 0.6.2. inside. However Serviio did not start when I rebooted the NAS. Serviio 0.6.2 works well when I start it with Putty SSH client using the sh serviio.sh command. However the moment I stop the Putty SSH, then Serviio server stops too. Did I delete something too much when I deleted the original /opt/serviio directory? Or is there a new install with Debian Squeeze + Serviio 0.6.2. to solve this. :
got the same problem...
tihob
Post Sun Sep 09, 2012 8:33 pm
Do you change the name of the serviio's folder ?
For understand how serviio is launching during the boot, you must have some knowledge about linux.
Please check the /boot/linuxrc file, if the line who launch serviio is correct !
