Not able to install Java - Synology
Bimha
Post Mon Sep 16, 2013 7:26 am
I am trying to install Serviio on my Synology nas, but I have problems installing Java.
When the installation start I received following message in attached file.
I have also attached picture of my file location in my server.
Any suggestion?
Br Birger
File location - Synology.PNG (70.61 KiB) Viewed 6870 times
Java Synology.PNG (24.1 KiB) Viewed 6870 times
Bimha
Post Mon Sep 16, 2013 7:30 pm
Re: Not able to install Java - XPEnology
HI,
I need to inform about the firmware I am using is Xpenolony installed on HP proliant Microserver N54L.
Br Birger
patters
Post Thu Sep 19, 2013 7:32 am
Re: Not able to install Java - Synology
You have uncompressed the Java archive. Don't do that. Leave it as a .tar.gz file.
