my problem on FreeNAS after install Serviio
akowit
Post Fri Aug 23, 2013 7:18 pm
i follow stem from http://wiki.serviio.org/doku.php?id=how ... ll:freebsd to install serviio on FreeNAS 9.1.0 on Jail, then after install Serviio and start it, have some problem show like this
Exception in thread "Thread-11" java.lang.RuntimeException: Cannot instantiate search engine: Cannot create directory: /usr/local/share/java/classes/serviio/library/search
at org.serviio.library.search.SearchManager.getInstance(SearchManager.java:59)
at org.serviio.MediaServer$ShutdownHook.run(MediaServer.java:335)
Caused by: java.io.IOException: Cannot create directory: /usr/local/share/java/classes/serviio/library/search
at org.apache.lucene.store.NativeFSLock.obtain(NativeFSLockFactory.java:171)
at org.apache.lucene.store.Lock.obtain(Lock.java:72)
at org.apache.lucene.index.IndexWriter.<init>(IndexWriter.java:672)
at org.serviio.library.search.SearchIndexer.startIndexWriter(SearchIndexer.java:193)
at org.serviio.library.search.SearchIndexer.<init>(SearchIndexer.java:79)
at org.serviio.library.search.SearchManager.<init>(SearchManager.java:49)
at org.serviio.library.search.SearchManager.getInstance(SearchManager.java:57)
... 1 more
something wrong ??
i'm noob for FreeNAS
some one help pls.
Thankkssssss
spikk
Post Mon Sep 02, 2013 8:02 pm
Re: my problem on FreeNAS after install Serviio
Seeing this error as well on a new install, never had any problems before :?
But I did a chown -R dlna:wheel /usr/local/share/java/classes/serviio/ to give the user dlna rights to the directory and it started to work again!
pitt1717
Post Mon Oct 14, 2013 2:43 pm
now with 9.1.1 out and the new package system which creates the jail etc., any chance of maybe packaging this up for the rest of us who do not like PLEX (which has a plugin built)? I'm no good at building these things and do not have any test environment for trial and error.
would love to be able to use my FreeNAS box for what i intended it for, streaming movies... btw, i'd be willing to help if i can
