Console not working on PC due to different versions?
HSH
Post Fri Mar 20, 2015 3:15 pm
Hi all, first of all compliments for Serviio, its really awesome.
I've been using it in the last year and half, without problems. My situation is the below:
Synology DS213J, version 1.4.1.2-002 installed and working. I'm using the console installed on PC to configure which folders to use, options etc
I was annoyed from the message telling me there is a newer version so i upgraded the one installed on my PC (windows 8.1 64bit), of course not the server components.
But now i cannot use the console anymore, it doesnt work.... cause on PC i have now 1.5.1 ! Any idea how to solve this?
thanks in advance!
Six
Post Fri Mar 20, 2015 3:18 pm
Re: Console not working on PC due to different versions?
Reinstall 1.4.1.
HSH
Post Fri Mar 20, 2015 3:33 pm
yes but i cannot find the old setup... :D
Six
Post Fri Mar 20, 2015 3:39 pm
Copy new link and change 1.5.1 to 1.4.1.2.
http://download.serviio.org/releases/se ... -setup.exe
HSH wrote:yes but i cannot find the old setup... :D
HSH
Post Fri Mar 20, 2015 3:41 pm
really appreciate this! thanks a lot!
i suppose i'll keep onreceiving the "old version" message at every boot, correct?
Six
Post Fri Mar 20, 2015 3:42 pm
Yep.
HSH wrote:really appreciate this! thanks a lot!
