Java failed to install Synology 213j
bcurrey
Post Wed Dec 24, 2014 5:51 pm
I've gone thru Petr's directions several times and can't get this to work. I enabled User Home service. I installed Java Manager. I added his package repository. I go into "Community" and try to install each of the 3 Java files and they all fail and give me "Failed to install Java XXX". I've tried installing using Chrome and IE.
Any ideas? Thanks!
bcurrey
Post Fri Dec 26, 2014 2:28 am
Re: Java failed to install Synology 213j
I worked on this a bit more. Here's where I'm at:
1) I installed the Java Manager package on the 213j
2) When I open it, it shows the following screen:
Java Manager
Java install manager.jpg (43.79 KiB) Viewed 16601 times
3) I registered on the Oracle site, and then went here: site: JDK7 for ARM Download
4) I download the top file labeled: Linux ARM v6/v7 Hard Float ABI 67.79 MB [​IMG] jdk-7u60-linux-arm-vfp-hflt.tar.gz
5) I go back in the Synology Java Manager, and browse to the file I just downloaded and install the software. It installs correctly.
6) I then go to the "Community" folder in the packages and try installing Serviio. It fails.
7) I also tried installing the Java 7 he has on his package site, and it fails as well.
Here's the instructions I'm going by on his site: http://pcloadletter.co.uk/2012/01/25/serviio-syno-package/
Is there another set of instructions that I should be going by?
bcurrey
Post Sat Dec 27, 2014 3:02 pm
Any suggestions? Please?
palmerito
Post Sun Mar 22, 2015 11:22 pm
Hello, I have exactly the same problem.
¿could you install it? ¿any idea?
