Serviio on Zyxel NSA310S
remus_ads
Post Sat Mar 21, 2015 9:08 pm
Hello. I recently bought a Zyxel Nsa310s NAS and i saw that for the 310 model there is a way to install serviio server. However, it doesn't seem to apply to the NSA310S.
Could anyone help me with a tutorial or something? (I am sort of a noob in the matter.
Thank you in advance
krys2two
Post Wed Apr 08, 2015 10:43 pm
Re: Serviio on Zyxel NSA310S
1. FFP on USB Stick -> http://zyxel.nas-central.org/wiki/FFP-stick
2. Look at the 325 tut -> viewtopic.php?f=14&t=13449
I tried to install Serviio serviio-1.5.2-linux.tar.gz on my NSA310S, but it does not start. Anyone a tipp?
sh -x /ffp/start/serviiod.sh start
+ EXEC=/ffp/opt/serviio/bin/serviio.sh
+ PIDFILE=/var/run/serviiod.pid
+ JAVA_HOME=/ffp/opt/java
+ OPTS=
+ test -x /ffp/opt/serviio/bin/serviio.sh
+ case "$1" in
+ echo 'Starting Serviio'
Starting Serviio
+ export JAVA_HOME
+ start-stop-daemon --start --quiet --oknodo --make-pidfile --background --pidfile /var/run/serviiod.pid --exec /ffp/opt/serviio/bin/serviio.sh --
+ echo OK
OK
+ exit 0
sh /ffp/start/serviiod.sh start
Starting Serviio
OK
sh /ffp/start/serviiod.sh status
Serviio shell is stopped
Serviio Java is stopped
Java is running:
root@zNAS:/ffp/start# java -version
java version "1.7.0_75"
Java(TM) SE Embedded Runtime Environment (build 1.7.0_75-b13, headless)
Java HotSpot(TM) Embedded Client VM (build 24.75-b04, mixed mode)
ps -ef | grep serviio
root     16852  6479  0 22:49 pts/0    00:00:00 grep serviio
norm
Post Thu Apr 09, 2015 5:42 am
Serviio 1.5 onwards requires java 8. Please see http://forum.nas-central.org/viewtopic. ... b83#p94057 for an updated tutorial to get it installed. Thanks
krys2two
Post Thu Apr 09, 2015 7:50 am
norm wrote:Serviio 1.5 onwards requires java 8. Please see http://forum.nas-central.org/viewtopic. ... b83#p94057 for an updated tutorial to get it installed. Thanks
Thanks! Now is is running.
krys2two
Post Thu Apr 09, 2015 9:44 am
Still have problems here with ffmpeg:
2015-04-09 09:37:22,586 DEBUG [ProcessExecutor] Starting lib\ffmpeg.exe -i /i-data/md0/video/frei$
2015-04-09 09:37:22,591 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "lib\ffmpeg.exe": er$
java.io.IOException: Cannot run program "lib\ffmpeg.exe": error=2, No such file or directory
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
        at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
        at java.lang.UNIXProcess.forkAndExec(Native Method)
        at java.lang.UNIXProcess.<init>(UNIXProcess.java:187)
        at java.lang.ProcessImpl.start(ProcessImpl.java:134)
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
        ... 1 more
But ffmpeg is installed and accessable:
root@zNAS:/ffp/opt/serviio/log# which ffmpeg
/ffp/bin/ffmpeg
root@zNAS:/ffp/opt/serviio/log# ffmpeg
ffmpeg version 1.2.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jun 24 2013 07:49:34 with gcc 4.5.4 (GCC) 20111110 (prerelease)
  configuration: --prefix=/ffp --disable-static --enable-shared --enable-gpl --enable-version3 --enable-nonfree --enable-small --disable-encoder=aac --disable-decoder=aac --disable-armv6 --disable-armv6t2 --disable-amd3dnow --disable-amd3dnowext --disable-mmx --disable-mmxext --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-vfp --disable-mips32r2 --disable-mipsdspr1 --disable-mipsdspr2 --disable-mipsfpu --enable-zlib --enable-postproc --enable-swscale
  libavutil      52. 18.100 / 52. 18.100
  libavcodec     54. 92.100 / 54. 92.100
  libavformat    54. 63.104 / 54. 63.104
  libavdevice    54.  3.103 / 54.  3.103
  libavfilter     3. 42.103 /  3. 42.103
  libswscale      2.  2.100 /  2.  2.100
  libpostproc    52.  2.100 / 52.  2.100
Use -h to get full help or, even better, run 'man ffmpeg'
The access rights are executable to everyone:
root@zNAS:/ffp/opt/serviio/log# ls -ls /ffp/bin/ffmpeg
144 -rwxr-xr-x 1 root root 142308 Jun 24  2013 /ffp/bin/ffmpeg
Any idea?
Added "-Dffmpeg.location=/ffp/bin" to /ffp/opt/serviio/bin/serviio.sh now i get this permissions problem, although ffmpeg has executable to everyone:
2015-04-09 13:36:22,464 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /i-data/md0/video/0802$
2015-04-09 13:36:22,465 DEBUG [ProcessExecutor] Starting /ffp/bin -i /i-data/md0/video/0802$
2015-04-09 13:36:22,468 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/ffp/bin": error=13, Permission de$
java.io.IOException: Cannot run program "/ffp/bin": error=13, Permission denied
Caused by: java.io.IOException: error=13, Permission denied
        ... 1 more
2015-04-09 13:36:22,473 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
Can anyone help?
norm
Post Thu Apr 09, 2015 5:40 pm
ffmpeg location should be '/ffp/bin/ffmpeg' . Also you might want to upgrade ffmpeg to be a later version. Make sure you have uli's uwsiteloader http://nas-tweaks.net/373/uwsiteloader- ... _plug-0-7/. Then run 'slacker -UaA br2:ffmpeg/'. Thanks
krys2two
Post Thu Apr 09, 2015 6:08 pm
Thx norm for your help, but it still not working. I dont get it.
norm wrote:ffmpeg location should be '/ffp/bin/ffmpeg' .
/ffp/bin/ffmpeg
ffmpeg version 2.1.3-compiled_by_barmalej2_for_Serviio1.4_and_MiniDLNA1.1.1 Copyright (c) 2000-2014 the FFmpeg developers
  built on Feb 13 2014 16:41:10 with gcc 4.5.4 (GCC) 20111110 (prerelease)
  configuration: --prefix=/ffp --disable-static --enable-shared --enable-pthreads --enable-gpl --enable-version3 --enable-nonfree --disable-armv6 --disable-armv6t2 --disable-vfp --disable-neon --enable-pic --disable-ffplay --disable-ffserver --enable-libx264 --enable-libshine --enable-libmp3lame --enable-libfdk-aac --enable-libtwolame --enable-libopus --enable-librtmp --enable-libass --enable-fontconfig --enable-libfreetype --extra-version=compiled_by_barmalej2_for_Serviio1.4_and_MiniDLNA1.1.1
  libavutil      52. 48.101 / 52. 48.101
  libavcodec     55. 39.101 / 55. 39.101
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
root@zNAS:/ffp/opt/serviio/log# ls -la /ffp/bin/ffmpeg
-rwxr-xr-x 1 root root 182396 Feb 13  2014 /ffp/bin/ffmpeg
Done. I had ulis (uli:ffmpeg-1.2.1-arm-1.txz) and now updatet to barmalej2.
krys2two
Post Thu Apr 09, 2015 6:48 pm
SOLVED
I´ve just removed the manually installed serviio and installed it through uwsiteloader -> slacker -a br2:serviio
