Intall Serviio 1.5 on a FreeNAS box within a Jail
pfonseca
Post Sat Feb 28, 2015 11:59 am
Hello there,
I'm installing Serviio 1.5 FreeBSD port on a FreeNAS Jail. Can anyone advise what options should I check when installing the different dependent modules, p. ex., ffmpeg or others?
Thx in advance.
Regards,
Edit 1:
Now is installed, but when I start the service, it aborts with this message:
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/MediaServer : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
Any clues??
Edit 2:
Solution on Edit 1 check this -> https://forums.freebsd.org/threads/net- ... dk8.50507/
phn2
Post Wed Jun 15, 2016 3:59 pm
Re: Intall Serviio 1.5 on a FreeNAS box within a Jail
Trying to make the same install but lacking a guide since im new to freenas?
Sendt fra min D5803 med Tapatalk
