Is there still support for Synology?
pur_berger
Post Thu Mar 19, 2015 12:47 pm
It has been a long time since any update and I wonder if there is something to expect ...
Best Regards
Markus
patters
Post Thu Nov 12, 2015 1:47 pm
Re: Is there still support for Synology?
The wait is over - 1.5.2 is out.
RTH
Post Wed Dec 16, 2015 7:25 pm
hi, I pointed out that since I use the version 1.5.2, all streams online do not work anymore.They worked at version 1.4.2.
Synology DS214Play Java 8 Serviio 1.5.2 Pro
patters
Post Thu Dec 17, 2015 2:01 pm
So I can test this are you using the Hardware Encoding FFmpeg 2.0.2, or the regular FFmpeg 2.7.1?
RTH
Post Mon Dec 21, 2015 10:29 am
livefeeds which version should I use?
There are now new Plugin?
in the next version, now just to save online-Fonts, why not save all settings Serviio Console? bringing the version 1.4.2 to 1.5.2, I had to put everything manually.
patters
Post Fri Jan 29, 2016 11:30 am
Online resource parsing was broken in the 1.5.2 package with FFmpeg 2.0.2 (evansport). It should be fixed now in the new 1.6-0029 package. Many of the online plugins I used to use are no longer actively maintained, but I have successfully tested YouTube with my Serviio 1.6 package.
