Unable to use Serviio 1.8.32 with JRE 8.101
DEJ710
Post Fri Mar 24, 2017 11:36 pm
Hi zip,
What would cause Serviio not to run after installing JRE 8.101?
engine_error.log shows problems with shared libraries libdl.so wrong class ELF expecting ELFCLASS32.
How do I fix this please?
https://PrivateLadyEscorts.com - Meet Local Singles - No Selfie - Anonymous Adult Dating - Secret Local Dating
Post Mon Mar 27, 2017 7:07 pm
Re: Unable to use Serviio 1.8.32 with JRE 8.101
it looks like a problem with the JRE - some 32 vs 64 bit compilation.
DEJ710
Post Tue Mar 28, 2017 10:40 am
zip wrote:it looks like a problem with the JRE - some 32 vs 64 bit compilation.
Hi zip,
Here is the full error message.
/share/CACHEDEV1_DATA/.qpkg/JRE/jre/bin/java: error while loading shared libraries: libdl.so.2: wrong ELF class: ELFCLASS32
Post Tue Mar 28, 2017 2:41 pm
yes... so that is somethiing wrong with the JRE package.... maybe try to remove Java and add it again?
DEJ710
Post Wed Mar 29, 2017 7:46 am
I have already tried that several times.
Are you able to test this at all?
Also, will the next version of Serviio include a bundled JRE like you did for the windows version?
Post Wed Mar 29, 2017 6:58 pm
No, it won't include bundled JRE on QNAP. I don't have 4.3 yet, so can't test.
DEJ710
Post Thu Mar 30, 2017 7:46 am
I don't have 4.3 either - only 4.2.4.
If I upgrade to 4.3 will this fix the problem then?
Post Thu Mar 30, 2017 8:05 am
No idea, maybe, as 4.3 is 64 bit AFAIK.
I assume that just executing java in SSH on the NAS gives you this error.
RMcV
Post Wed Apr 19, 2017 1:01 pm
@DEJ710
Yes, upgrade to OS 4.3.., install JRE 8.101, uninstall 32-bit Serviio, install 64-bit Serviio and you will be good to go.
I think your problem is that JRE 8.101 is 64-bit and your old Serviio is 32-bit. Do the steps I mention above and your problems should be gone.
DEJ710
Post Sun Apr 23, 2017 12:29 am
@RMcV
Thanks for your response.
I updated to qts 4.3.3, JRE 8.101 and Serviio 1.8.64 last night and here's what I did:
1. Update to qts 4.3.3
2. Update JRE to 8.101
3. Upgrade Serviio to 1.8.64 (Install over the top) using download from serviio download link
Serviio is still functioning and my library is still in tact
