Problem after installation on Synology NAS
greekdroid
Post Mon Jun 10, 2019 9:53 am
Hi
After upgrading to version 2.0, I get the following messages. Also, I can not log in via MediaBroswer anymore. The entry where I can capture the users is missing.
Thank you for your help
FM1
2019-06-10 11_47_35-Microsoft Edge.png (38.79 KiB) Viewed 12495 times
2019-06-10 11_48_04-Window.png (48.97 KiB) Viewed 12495 times
greekdroid
Post Mon Jun 10, 2019 12:00 pm
Re: Problem after installation on Synology NAS
The problem is solved. It's up to Chrome.
Sebastian_T
Post Sat Jun 15, 2019 5:44 pm
Not only Chrome, also Mozilla Firefox - the same.
Post Sat Jun 15, 2019 9:33 pm
Actually you just need to clear your browser cache. There's quite a difference with V2.0, and anything remaining in the cache messes up the console.
patters
Post Fri Jun 28, 2019 8:41 am
... which is why I put a message to do this in the "What's new in this version" text that gets displayed in Package Manager :)
Updated to Serviio 2.0, clear your web browser cache to fix Serviio Console issues
Sebastian_T
Post Mon Jul 22, 2019 6:07 am
Another problem found.
Was not present on earlier versions. After update to 2.0 - Serviio (on Synology NAS) dissappears from the network - have to stop the Serviio process in Synology and restart it, only after that server apppears in network and can be used normally.
After some hours (eg. night) of not using situation is the same - have to restart the process. AND - I can see Serviio via computer, but cannot see on other devices, like TV; restarting server via Serviio console does not help, has to be restarted in Synology system.
