Synology 100% cpu due to "scan" on changes
stappel
Post Wed Apr 29, 2020 12:19 pm
I noticed my Synology was running for almost 100% for a couple of days now. If i look at the log it started with the DSM 6.2.3 update.
It is Serviio who is detecting “changes” in the movies folders. in the serviio.log it shows:
    2020-04-29 14:06:09,079 INFO  [MediaFileIndexer] Updated 'Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY' (/volume1/video/Films/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY[rarbg]/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY.mkv) in Library
    2020-04-29 14:06:15,168 INFO  [MediaFileIndexer] Updated 'The.Conners.S02E19.720p.HDTV.x264-AVS' (/volume1/video/Series/The Conners/The.Conners.S02E19.720p.HDTV.x264-AVS.mkv) in Library
    2020-04-29 14:06:26,235 INFO  [MediaFileIndexer] Updated 'Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY' (/volume1/video/Films/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY[rarbg]/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY.mkv) in Library
    2020-04-29 14:06:31,756 INFO  [MediaFileIndexer] Updated 'The.Conners.S02E19.720p.HDTV.x264-AVS' (/volume1/video/Series/The Conners/The.Conners.S02E19.720p.HDTV.x264-AVS.mkv) in Library
    2020-04-29 14:06:43,053 INFO  [MediaFileIndexer] Updated 'Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY' (/volume1/video/Films/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY[rarbg]/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY.mkv) in Library
    2020-04-29 14:06:48,189 INFO  [MediaFileIndexer] Updated 'The.Conners.S02E19.720p.HDTV.x264-AVS' (/volume1/video/Series/The Conners/The.Conners.S02E19.720p.HDTV.x264-AVS.mkv) in Library
    2020-04-29 14:06:58,075 INFO  [MediaFileIndexer] Updated 'Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY' (/volume1/video/Films/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY[rarbg]/Extraction.2020.iNTERNAL.1080p.WEB.x264-SECRECY.mkv) in Library
so every 5-10 sec it detects a change in the new downloaded files. if i reboot Serviio it stops. But then with the new file downloaded/found it starts again.
also when i disable the option "Keep library automatically updated" it stops. When enabled it is quiet until a new file is placed in a folder.
Anyone else seeing this?
MrMattWard
Post Tue Jun 23, 2020 6:35 pm
Re: Synology 100% cpu due to "scan" on changes
Yeah i have seen something similar.
I removed Serviio and uninstalled FFMPEG as well.
I also Disabled a File Services setting in Advanced called SSDP (WIndows Network Discovery) it share the same port as DLNA (1900 UDP) and I suspect the two were messing each other around.
Then i reinstalled Serviio only and all is OK.
Good luck.
MrMattWard
Post Tue Jun 23, 2020 10:52 pm
Actually... it happened again... not doing massive cycles but it's definitely just one folder particularly its doing it too.
Im gonna keep on investigating
MrMattWard
Post Thu Jun 25, 2020 12:02 pm
Ok so this was happening again after the above so i swtiched off some settings in Serviio... First was Generate thumbnails for local Videos and also Look for a local DVD Cover image or poster. Its calmed down.
Enable the Debug logs and see what its doing... i was supprised at how active it was in doing indexing... it would be nice is the MetaData Controls were a bit more granular about what you wanted it to capture and process... I have no interest in knowing directors and actors associated with my movies.
