volumes no show
rivoli145
Post Tue May 19, 2020 1:07 pm
volumes no show
Hello
I just install serviio after installing new version of my macbookpro : catalina version 10.15.4 and my volumes are not appearing when i check on the serviio consol
Could you help me
Post Tue May 19, 2020 1:16 pm
Re: volumes no show
So, to be certain I understand. When you open the console and want to add a folder location to your shared folders, when you click the Add button you don't see any of the file locations, or you don't see specifically your media locations? Are your media files stored on a drive attached directly to the computer, or are they on another networked device?
I'm not familiar with the MacOS, so I can't say for certain how it works. On Windows, Serviio by default runs as a system service, which can access local drives but not networked locations. So we need to clarify where you media is located.
AlisonMoss
Post Sat Jul 18, 2020 4:46 pm
Re: volumes no show
Where are my files in the consol? All have been scanned, there are 2021 as per under the Green Movie picture, but I can't see where they are. And when I go to the server on the net, nothing there, all empty.
