Serviio package for Synology
heinsolo
Post Sat Aug 22, 2020 9:49 pm
Hi community!
Is there no Serviio version for the Synology DS920+ (Intel Celeron J4125 CPU) ?
Settings in Package Center are correct (https://packages.pcloadletter.co.uk, certificate is also installed correct) but only one Community package from https://packages.pcloadletter.co.uk is shown:
Open Remote.
What can I do to get the Serviio package ?
THANKS for any help.
Greetings
Heinsolo
Post Sat Aug 22, 2020 10:52 pm
Re: Serviio package for Synology
The Serviio download page (https://www.serviio.org/download) has a package for Synology, although it's still version 2.0. The person responsible for creating the NAS packages hasn't updated it to 2.1 yet.
heinsolo
Post Sun Aug 23, 2020 10:45 am
Hi Dan,
thanks for your help, that is exactly what i did. The site https://www.serviio.org/download links to a site where you can add the site https://packages.pcloadletter.co.uk to your package sources in the synology nas.
But it shows no Serviio package just one package named "Open remote" - nothing else.
Other sources (e.g. https://www.cphub.net/) works fine - i can see all packages.
Is there another source for the Serviio package ?
Thanks for any help!
Post Sun Aug 23, 2020 11:32 pm
Sorry about that. I've never had a NAS device, so have never tried the install. Perhaps Patters will join in here, as he's the most experienced with NAS installations. However, I see he hasn't been on the forum since May, so it might be a bit before we hear from him.
Acetone
Post Tue Aug 25, 2020 9:44 pm
It works fine for me, but the one small thing I can see is you have used https:// and on Patters site and also on my NAS it's plain old http://
I don't know if that is the issue but worth checking, Also don't forget you need the Java SE Embedded package installed too.
heinsolo
Post Thu Aug 27, 2020 3:27 pm
Hi Acetone,
thanks for your post. I made some investigation on the NAS. Problem is a wrong certificate that could not be deleted - it is "stucked" on the nas. Im not able to post the complete decription of the problem in english - it is not good enough :-(
But the problem has nothing to do with Serviio it is a Synology problem. So this thread can be closed.
THANKS for your help !
jne
Post Sun Oct 11, 2020 7:01 am
I have the same problem; Serviio is not in the package list even after adding PCLoadLetter as package source. Or maybe it is not yet available for DS220+? I tried to post a comment on the PCLoadLetter web page but no answer yet and it seems a bit abandoned in general. No posts from patters since February.
I also cannot delete the PCLoadLetter certificate, even after deleting PCLoadLetter as package source. @heinsolo: Any hints on how I can remove the certificate since you seems to have succeeded in doing that?
Post Sun Oct 11, 2020 9:57 pm
Patters' user account haven't shown any visits since May. I have no idea if he's still making Serviio updates. Hopefully he's simply unable due to workload or something.
heinsolo
Post Wed Dec 09, 2020 6:03 pm
@jne - sorry for the late answer.
My english is not good enough, I try it :-)
My problem was the "stuck" certificate.
Under source it was "http://packages.pcloadletter.co.uk" but under certificate it was "httpS://packages.pcloadletter.co.uk".
So when I removed the source with only "http" the certificate with "httpS" stays there.
It took a long time for me to notice the difference :-)
I add the source with "httpS" and was able to remove the certificate.
I add the source with "http" again and the correct "http" certificate without "S" was installed.
But: Still no Serviio package in my list :-(
