Serviio not work in Synology DSM7
Skafo
Post Sat Mar 26, 2022 11:06 am
Hello. I am user of licenced Serviio version 1.10.1. in DSM6. After my Synology NAS DS918+ upgraded from DSM 6.2.4 to DSM 7.1 was impossible to install serviio package, the message was corrupted file. I tried install normally from Centrum packages and also direct from file without success version 1.10.1 and version 2.1 also, same message. PCLoadLetter.co.uk was set correctly. Do you have some advice or tutorial how to setup Serviio in new DSM7 or will be available only with expected version 3? Thank you very much for answer. Skafo
Post Sun Mar 27, 2022 3:43 am
Re: Serviio not work in Synology DSM7
There are a number of other threads about this specific issue. Apparently Synology broke something that Serviio needs, but they don't seem to be in a rush to fix it.
Sargon
Post Tue Mar 29, 2022 12:53 am
atc98092 wrote:There are a number of other threads about this specific issue. Apparently Synology broke something that Serviio needs, but they don't seem to be in a rush to fix it.
Synology isn't going to be "fixing" anything. Unfortunately, it looks like it is going to be up to Serviio to work within the new limitations of DSM7, and I'm not sure anyone is really interested in doing that.
Post Tue Mar 29, 2022 1:39 pm
The Serviio developer does not create the builds for NAS devices. They are supported by users that port them over. I know that person has been working on it, but since I have no knowledge of NAS devices I can't say if it's going to be possible to resolve.
