New QPKG Serviio_2.2.1_x86_64 (Fix)
Muttetjeff
Post Fri Sep 23, 2022 12:00 am
Hello
I just finished compiling a QPKG to fix the bug of the QTS 5.0.1 version refusing to install or start.
I tested it on a TS-253D and everything works perfectly. I also took the opportunity to put the thumbnails in HD by default from the first start.
Could a moderator or administrator tell me how to put it here as its size is 38mb.
ksergey2012
Post Fri Sep 23, 2022 11:47 am
Re: New QPKG Serviio_2.2.1_x86_64 (Fix)
Dear Muttetjeff, place the file of the corrected Serviio, for example on Google Drive and give a download link. Thanks in advance!
Post Fri Sep 23, 2022 1:14 pm
You will have to put them as mentioned somewhere online with guest access. This forum doesn't support attachments that large, and there's no way around that.
